RedWheelz
Snow Blower compatibility question
RedWheelz
I got a C-121 and was wondering if a model 06-37SK01 snow blower will fit it?
Thanks for any help!!
Ed Kennell
file:///C:/Users/umpa/AppData/Local/Microsoft/Windows/INetCache/IE/L25QUUTB/WH Interchange 1955-2000.pdf
Open this file and scroll down till you find your C-121.  Page 22
You can also find your blowers manual in the manuals/blowers section and compare it to blowers that are known to be compatable  with your C-121.
Edited by Ed Kennell
JAinVA
Ed,
   I couldn't open the file you posted.It might just be me but just in case I thought I'd tell you.I looked in the manual section and I don't think that blower would go on a c series without modification.
Walt
 06-37SK01  Snow Thrower is for a vertical shaft engine powered tractor.
JAinVA
Thanks Walt I thought that's what it looked like it fits.
Ed Kennell
Thanks Walt and Jim.   That file would not open for me either.     Above is the file from the manuals/misc  section I was trying to copy/paste to show the blowers that will work.
gwest_ca
The attachment list is good but leaves out many models. It includes the original unit, the unit that replaced the original and the unit available when the list was made. It leaves out the models between the last two.
There is a list of models here that go back to the first 37" snowthrower for the C-Series tractors that started in 1973 with the introduction of the front quick hitch. Everything from 1973 on will fit.
Garry
Walt
Garry is correct it will fit, but the drive may not work without some modifications. I have modified a vertical shaft snow thrower to use on tractor with a horizontal shaft motor. It was a bit of work and a couple of hundred dollars in parts to complete. I enjoyed the project and it did nice the 2 times I used it this winter. This being said I will more than likely not use it again. The reasons being are my feet got cold setting on my butt clearing snow, and dressed exactly the same way I stay toasty walking behind either of my smaller snow blowers. Also I only own 1 tractor and want my blade on it in winter. I also have limited storage space in the winter since I store my car in the winter.  Lastly I have no desire to own a second tractor just to be able to run the snow thrower.  Guess I'm neither a collector or a hoarder simply the owner of a worker.
Maynard
I just bought a wheel horse raider 12 wanting to put a snowblower on it will a snowblower from a newer model fit? Or do I have to get the older  style if I can find it? Looking at model #79263
gwest_ca
The 79263 fits tractors with a vertical engine crankshaft so the pto is below the engine. Requires extensive modifications to change to a side pto as Walt did to fit a long frame tractor like the Raider or C-Series or 300-500 series models.
The post I made in 2017 no longer has the list of compatible models. It is now here. Click on the picture
You can add a front quick hitch to your tractor so 1973 and later front mounted attachments will work including mower decks.
Garry
  • Similar Content
    • jledonne
      By jledonne
      1966 Lawn Ranger PROJECT
      L-106 Lawn Ranger with non-running Tecumseh H60, 6hp.  Engine lost compression, reads 25 PSI.  No visible external damage to block or cyl. head.
      Mostly original, one owner tractor w/ 32” mower deck and 32” snow blower (STR-3240) both serviceable.
      Very good sheet metal.  Original seat has tears.  Newer carburetor, original included.  New recoil starter (uninstalled).  Replacement front wheels/tires.  Originals included, one has broken hub.  Original rear WH tires.  Two sets of tire chains, one new w/ tensioners.  Box of small parts and original documents.
      Good candidate for restoration or repower conversion.  $275 OBO.  60+ high-res. photos online, PM or call/text 610-248-6471 for link.  Located in PA, 18072.
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • PWL216
      By PWL216
      Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
    • BobandJamie Raay
      By BobandJamie Raay
      400 Series WheelHorse Garden Tractor w 42" deck in good condition. Has a frame issue under the seat (needs welding) but runs well. 17-horse Kohler engine on tractor.
      Extra rear discharge mulching deck (42"), extra set of blades for mulching deck and side discharge deck,  snow thrower (42" with 20" chute) and trac vac with 5.5 horse Honda engine in good, working condition as well. All 4 hubcaps are included (rear not in tractor picture but see additional pic). Original paperwork, including owner's manual on all. Includes chains for snow traction and weight attachments for each wheel. All have been used at the same property since purchase and have been stored indoors throughout. Thanks for looking!
