Aldon
GT22-8 Modifying GT14 to 8 speed and 22hp Predator
GT14
I up graded my GT14 a few years ago with a Kohler Command CH18 still need to redo the hood to put on the decals.
Aldon
The Decals really are a nice finishing touch!
HUDSON89
I Like what I'm seeing keep the updates coming :popcorn:
19richie66
That thing looks mean. :popcorn:
Aldon
So I've expanded my repertoire lately and have some personal stuff going on that may eat up a lot more of my project/play  time than I'd like.
But I'm making some progress and figured I would throw up an update.
i got the Backspace figured out for the custom rims and I've shown the pics in another thread but they really belong here. @fast88pu did me a favor and welded the centers into the blanks for me. He has access to a bigger welder.
In another thread I was asking for ideas on the axle pin. As I got into it more, the swept axle is straighter than the GT14 so the bracing had to get cut out and new axle pivot pin braces or brackets or whatever you call them will need fabbed up. I have spare frames so I cut the transmission plate from two of them and will flip them over to extend the axle pin lower towards the ground which will allow the straighter 520 axle to clear the Fran and have some swing movement. I can also drill the axle pin holes to 3/4". I don't have a plasma cutter or a cutting torch so these plates were removed with cutoff wheel. Lengthy and tedious. Still need to make some mods to the plates. For instance, I need to notch the plates so the axle is not all the way to the front.IMG_0771.thumb.JPG.8d6a2a356497ea18e713218d93697085.JPGIMG_0786.thumb.JPG.c04948513d24d9eab8016cefd2f09979.JPGIMG_0790.thumb.JPG.0e0f9fafc9a9f5e7ca65778d669ee35d.JPG
No no way this or my other RJ35 resto will make it to show. Bummer. But at least I am picking up a couple tractors while I'm there.
Edited by Aldon
  • Like 6
Aldon
So cutting metal without a torch or plasma cutter is a royal pita.
Had some major home maintenance tasks the past couple days but I did squeeze in getting the braces fine fitted. Gonna tack weld them together and drill the pivot hole.
IMG_0798.thumb.JPG.ba3d31b747e044447d70c6d0c09ad65f.JPGIMG_0794.thumb.JPG.5adaa82e535d9f6b07b921dc62574d63.JPGIMG_0795.thumb.JPG.846e078380bfd2608a6751707a693232.JPG
  • Like 6
Sarge
Might want to sandwich those plates together and drill the pivot hole through both at once - better chance of keeping things aligned correctly .
Sarge
Aldon
Sarge
Exactly the plan. Going to do a couple tack welds. Then drill. Will weld braces in place with pin installed to asssit with alignment.
Aldon
Ok. Finally getting back to this project. Tacked the two plates together, drilled the pivot and its mocked in place. Tomorrow I'll weld the braces in place and this should release the flood gates on this project. Although the reduced gear set up will need to be modified quite a bit. Due to the larger rear tires, I added about 1.25 inches to the front to give it a more level final look.
IMG_1133.JPG.4a85a61ac41827a30eb85cdd09e6224b.JPGIMG_1134.JPG.32478d4ad59086641dfeea52847e2082.JPG
  • Like 4
fast88pu
Drinking 40's while doing it ?? Lol
Aldon
That's the spray wax in close proximity. Ultimate optimism!!
fast88pu
Ah ok
Aldon
Got it all welded up and the front brace is beefed up. This was a ridiculously weak piece on gT14's. It was thin and flimsy as they used a side mule pulley set up. I had to buy a piece of steel which is the first other than the rod for the pin and steering shafts. Otherwise I've tried to recycle from the parted out Horses.
The axle pin is retained with a tab and bolt. I did not need beefier steel here as it really takes no abuse but what the heck....might as well go all in. It is perpendicular to what it was when stock as I need the real estate between pin and frame for the bulkhead bearing. Part of the change over from original steering to gear reduction.
I may touch up some of the welds tomorrow as it was getting dark.
IMG_1136.JPG.30e0c1e7ede9b0bc79a2aa7867b7f1c6.JPGIMG_1138.JPG.0e9bfc527eb5497cb41d4b5933072737.JPGIMG_1140.JPG.efcd37e7152b724d8e95e09612e8762f.JPGIMG_1141.JPG.779c3a6e31c275cb516615cc197a2acf.JPGIMG_1142.JPG.8fdb167296f406adb182de8bfe1c5251.JPGIMG_1143.JPG.6133513c388e7817fd1b1cd7120b64fc.JPG
  • Like 9
JPWH
Looks good Aldon. That is what I like to see with a build. Stripped to the frame and work up from there.:bow-blue:
Edited by JPWH
Aldon
Thanks Jay. I new this one would require welding etc. so I went to the metal and coated it all with rust kutter from tractor supply. No rust after several months of sitting in garage waiting on me to get going on it. I'm gaining momentum now.
Edited by Aldon
  • Like 4
GT14
That's allot of beef up front, Are you adding a bucket?
Aldon
Yes. That is the mid range plan.
Aldon
Tackled the 520 Gear reduction today. This thing is going to be really stout. Upgraded to a true bulkhead bearing for support of fan gear shaft that goes to front of tractor.
The excessive length of TH of steering wheel is due to 520 was too short. So I cut the gear end off and had a machinest lathe the end of a long rod. I welded gear on and will cut to length when I decide how tall I want the steering wheel to sit.
I also ended up having to shorten the fan gear rod on the end that attached to front bulkhead by ~ 7/8 inch. Luckily this left enough space SK i did not have to remake this piece. Should have it on its own wheels tomorrow.
IMG_1170.JPG.38460d5ccdf4d65a25b8ebf590a1deb6.JPGIMG_1171.JPG.bfddf8c11774f8d69404b395c4a91e0c.JPGIMG_1174.JPG.b5f567e9719f9a7e586f38058fceecb5.JPGIMG_1175.JPG.ca722ee60206c7a8fbbb65c0ea822edb.JPGIMG_1178.JPG.44f8359c77e423dacc9df142d8ba99fe.JPG
  • Excellent 7
19richie66
As always, very nice work. Hoping to have a power steering box sitting in mine soon. Fingers crossed.
Edited by 19richie66
Electro12WH
I have so many questions to ask and I'm just holding my breath waiting to see what is next!
Aldon
It was slow going as I struggled to get the 520 tie rod ball joints loose on the tie rod. And I had incorrect seals for front wheels. While skf 12407 matches dimensionally with toro part number the rubber seal does not protrude similarly so I finally cleaned up and prepped the originals. They should last several more years. But time slips everywhere on a build.
Pictoral update with wheels, tires and steering installed. 14" from surface to bottom edge of frame. It is level as well. In some pics it looks like it may not be but that is illusion.
IMG_1187.JPG.004739af0043c040391a0b3ad87eb76f.JPGIMG_1189.JPG.9d4d985cf57975671980f4fb2bfccd69.JPGIMG_1190.JPG.42b88bd784f27b452320dd28cfa728f9.JPGIMG_1191.JPG.c7ecec3348c1e129d62a704d434e890f.JPG
  • Excellent 7
JPWH
Looking good Aldon. Those big tires should handle anything you want it to.
19richie66
 Very nice. Looks killer with those wheels and tires. :thumbs:
stevebo
It is looking really nice. It is just mean looking.
mmmmmdonuts
Looks great so far Aldon. Keep up the great work.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
