Aldon
GT22-8 Modifying GT14 to 8 speed and 22hp Predator
bmsgaffer
I am following this one! It sounds awesome and I look forward to your progress!
WHX??
I've seen your work Aldon, I'm in as well!
953 nut
:woohoo:   Been looking forward to this one. The six speed Transaxle from a 1057 or 1267 (5060) is a limited slip and they work great, I have one in one of my 953s. You may be able to pick up the center section from one of our parts vendors.
Aldon
What diameter axles are one those?
953 nut
5 minutes ago, Aldon said:
diameter axles
1 1/8
Aldon
Hmmmm. Well if I run across a parts tranny from 953 or 1054 before I start mocking things up, then there is still a chance this could end up with a limited slip.
Otherwise, I plan to try and mount Go-Kart disc brakes to the backside of the D-series Hubs as they have 4 tapped holes conveniently located on backside. Spaced 2 3/8" inches apart. I am not absolutely certain this will work until I mock it up and custom set wheel backspace. But it works in my head! LOL
The brakes, essentially turning brakes, can be my poor mans limited slip.
Edited by Aldon
WHX??
We kinda had this discussion about the 5060 and it's pros/cons for a plow tractor transmission the other day when I visited @Shynon's. Not that you might plow with it Aldon but anyway it was brought up if that 50 yo spring were to break in there... yikes. Another con is the aluminum side plates that holds all those pinions in ther might not hold up to the rigors of plowing. Mike @prondzy actually showed me a side plate that was cracked due to overtorquing the differential bolts. Probably not huge concerns pending what you might use this machine for. We are just plowing fruitcakes and looking for the strongest unit for doing that. Either way double :handgestures-thumbupright::handgestures-thumbupright: for what you have in your head! :)
  • Like 3
953 nut
:no:   1067 or 1267, I transplanted one into a 953, the stock 953 is an open differential and not known for their strength.
  • Like 3
Aldon
Lol. :unsure:
I heard you that time:-)
WHX??
I got it the first time Aldon:ychain:....Richard that has got to one brutal 953 in the rear then!
mmmmmdonuts
Definitely very interested in this thread. Just out of curiosity which 8 speed tranny do you actually have model wise? The 8 speed / 8 pinion would be the strongest but I don't think it has limited slip. My Raider also has the 5060, which is the 10 pinion limited slip with the 1-1/8 axles. I also read in a different post about modifying a 10 pinion it to an 8 pinion (albeit with some grinding).
Aldon
The tranny is a 8 speed 8 pinion. But the blessed maker likes to challenge me. So somehow I ended up gettting one of the few 8 speeds that they ran out of 1533 bearings for and used a unique bearing on. @Racinbob and @stevasaurus identified as a 111199 if I recall.
 Some pics of the state it was in when I got it....it's not obvious but the hi-lo shift fork was broken. I have new parts ready to install as it goes back together. Also a pic of the unique bearing.
I have been been unable to locate new bearings to replace. If anyone knows of a source, send me a note. Thanks
  • Like 3
Aldon
Thanks. Much appreciated.
I think I spent all my time trying to find the bearing elsewhere using the  S875B part number on the bearing. ***** I just ordered a pair ! *****
For those interested, here are some pics of the bearing comparisons, along with what I was able to measure them.....disclaimer "I am not a machinest" as such, take that into account. also a couple pics of the broken shift fork and the NOS parts. I will capture tractor stuff in the next post for those concerned that this thread is too Tranny heavy:roll: LOL
Pics of GT14 Hydro Diff vs 8 speed 8 Pinion Diff before modification.
Edited by Aldon
  • Like 6
WHX??
4 hours ago, stevasaurus said:
(1968) had aluminum end plates...1969 and up have steel end plates
Not to steal your thunder or thread  Aldon but @stevasaurus my 67 had AL plates and can the steel end plates be used on earlier units? Do you think WH knew the AL plates were a weak spot and went to steel?
Those bearings are awfully close in dims Aldon but Lowell's won't work??
Edited by WHX9
  • Like 3
Aldon
Actually I was comfortable using the 1533's if I could not locate the correct ones. I had planned on using the green loctite and using a punch to deform the edge as I expect new bearings to far outlast my needs. However since I was directed to correct bearings, Ill use them and save a potential future owner the hassle of having to heat the bearings and extra effort to remove the punch areas.
This is the product I had planned on using but will not require now.
Edited by Aldon
WHX??
Yes that's a good product to have on the bench anyway. Hope you don't give up on the dual brakes idea tho! :)
stevasaurus
OK...the 5060 trans had aluminum plates...the 5071 and 5073 had steel plates.  :)  and yes you can interchange them.  Actually, the #5060 I rebuilt had one of each...tells me someone else has been in there.   :occasion-xmas:
  • Like 4
dclarke
Pretty interesting build, Aldon. I'll be following this also.
19richie66
I am along for the ride.
Aldon
It may be a while before I post anything of significance although I'll respond to questions.
As of tonight I finally cleared the latest significant hurdle. And I am embarrassed to say how happy I was to accomplish such a simple feat.
I have wrestled on and off for weeks and tonight I finally managed to break that danged hitch pin loose from the larger half of the tranny case. I was concerned I was going to crack the casting but it finally gave up!!!!!
And since it seems silly to post such a minor event, I'll post a couple pics of the D-series hub for those not familiar with them. The 4 threaded holes on the backside are where I am considering mounting a go-kart disc brake set up to act as turning brake and assist as a poor mans limited slip diff.
  • Like 4
fast88pu
See you got the pin out
  • Similar Content
    • tractorboy79
      By tractorboy79
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
