fast88pu
Inside and outside cast wheel weights?
fast88pu
Are these inside and outside cast wheel horse weights? I've never seen the ones with the notch for the valve stem before. Rare??
  • Like 4
953 nut
Some rims have the valve on the outside (deep side) of the rim, 1267 did.
new2horses
I've been told that the weights with the notch were made for the "D" series. Wheel Horse none the less.:handgestures-thumbupright:
fast88pu
I didn't think about the d series rims
857 horse
My 857 has a set on the inside and outside..........I will go look,,,,,,
squonk
I don't believe those weights were actually made by :wh:. I have seen many makes of garden tractors with the same weights. As a matter of fact 1 set I have came off of a Cub Cadet and the guy who had them said they were off his tractor that he bought brand new in the early 70's.
fast88pu
I got them at a wheel horse dealer and were still in the wheel horse box
  • Like 3
squonk
More than likely an independent co. made them for the various tractor manufacturers and boxed them up with the correct co. logo. Kind of like how Allied made a lot of the WH implements and later on Ohio Steel.
Edited by squonk
whfan74
They are both outside weights.
Tankman
I believe the inside weights are two piece. Never tried inside weights.
Use wheel weights for pushin' snow, gravel. dirt.
Always front weights when turnin' earth. Made a front bumper that'll support suitcase weights. :handgestures-thumbupright:
