IBleedRed
Kohler 25hp Command Pro swap into 520-H
Cable
Excellent write up.  Appreciate your effort to share this change.
slammer302
It looks great to me. Thanks for the wiring info. I've wanted to do a similar swap in the future.
AMC RULES
Yeah...should be a nice upgrade there.   :text-bravo:
IBleedRed
Yup, just waiting for the next big snow storm to give it a real test.
Has as anyone heard of a break in procedure for these engines? Google didn't seem to know.
cschannuth
Whenever you run the engine make sure it is warmed up for a few minutes before running at full throttle and idled down for a couple minutes before turning it off. Both of those procedures will make that new engine last for thousands of trouble free hours. I would change the oil after the first 5 hours (some would say after 10) and then again after 25 hours. After that you should be good to go with normal maintenance.
Edited by cschannuth
Clarity
  • Like 3
roadapples
Guess that will make it a "525-H"   :woohoo:
WildHorses
What's the belt guard looking thing in the top final image? Is that a custom piece?
dclarke
Lots of good information here, thanks for sharing.
IBleedRed
Not really sure what your referring to, but that bit on top of the muffler is just a heat shield. If I wanted to get away with out cutting the hood I could have cut that off instead.
Tuneup
Wow! Great job and with V-Twin torque, those rear tires and weight - she's an incredible puller. As for break-in, we all have our methods. It's my opinion that an air cooled engine has cooling capacity based upon full load. I would get the oil (basic dino oil) warm off idle and then run a good load like a deck for up to 30 minutes to stress the rings. After that, remove the load and run full throttle for max cooling for a minute then idle for 10 seconds to clear the muffler of un-burnt fuel if needed before killing it. My Kohler K301 rebuild had minor smoking from blow-by at the start but she was running clean after this break-in. So, there's some opinion on a Sunday for ya :)
DougC
Great job! Enjoyed your thread.  :handgestures-thumbupright:
IBleedRed
Thanks for all the compliments. I thought if nothing else I could save someone a bit of time on their swap.
EricMassey
Awesome swap! I'm wondering what size the front tires are and are they the v61's? If so I've been wanting a set for my 520-h but can't decide on the size. Thanks!
IBleedRed
V61 16x6.5-8's on the front, easily the best purchase for the tractor I've made so far. The tires plus the gear reduction makes it like power steering at half the cost. Even with the loader steering was a breeze.
bmsgaffer
I just finished a swap into a 522xi with the fuel injected version of that exact same engine. I only have some minor exhaust routing modifications remaining. Awesome engines and it looks awesome stuffed under that hood.
I had thought that Kohler twins were not rated for the PTO side-load and that's why many places were using the Briggs Vanguard for replacement. Any thoughts on that?
Did I read you right that you were planning a black-hood swap? I had a plan like that for a while and never found time (then found and XI) so I sold the parts. That would be a sweet looking black hood, and I think they give just a bit more clearance for the muffler than the 520 hoods.
Have you tried fitting the chrome muffler shield from the 520? I think that would be the icing on the cake for that swap.
:handgestures-thumbupright: :handgestures-thumbupright:
IBleedRed
I know there's no bearings on the pto side of the engine, so that is a problem. It's a risk I'm willing to take for the circumstances. I'll keep updates coming if I see any premature wear.
I'm not sure because I haven't tried it yet, but I think I would have to cut the hood more to accommodate the heat shield.
Here's the black hood swap:
bmsgaffer
On some of the briggs models wheel horse produced, they put a plate behind tne PTO with a thrust bearing on it to take the side pressure. I have never seen it in person, only read about it. This may be an option worth pursuing to prolong the life of that super nice engine... just a thought.
It may have only cost you 400 now but to replace it would be over 1000!
Oh i thoughtthe black hood was going on this kohler twin tractor, i misread.
Northport
My 416-8 needs a rebuild or repower.  I found a Kohler Command Pro 23hp model CH730 for $400.  Your swap documentation is very helpful, and it looks like this could work.  My biggest concern is the PTO.  The output shaft is 1 7/16, did you have to modify your PTO or crank, or did yours come with 1 1/8?  Any assistance is appreciated.
IBleedRed
I got lucky, mine matched the Onan. Not sure how to help in your situation, but I imagine someone has done a right up on it. Best of luck with your swap.
19richie66
Going through the same thing with the same motor. You can run an electric clutch as this motor is used on a Vermeer stump grinder. So far thats the only option I have found.
Northport
I was also considering an electric PTO clutch,   I did find a write-up on someone who installed a similar motor on a Wheel Horse C160.  He had a machine shop cut down the shaft to 1 1/8, which is probably the most practical option.  He said they were able to do it while installed in the engine, but I'm guessing I'll have to remove it for anyone around here.
I did find that this motor is available with 1, 1 1/8, and 1 7/16 shafts, but the best I've found for a new 1 1/8 crank is $300 plus shipping.  I'm looking at a motor with 200 hrs, but don't want to spend a fortune modifying it.
John Deere used the Onan's with 1 7/16 shafts, but their pto's are significantly different.  Good Luck
19richie66
good luck. Post back here if you find a good option. Mine won't be used for mowing so I only need the drive pulley on the engine at the moment. I have some ideas but nothing that wouldn't take some work to do.
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
