todd white 0 #1 Posted January 13, 2017 Hi guys! Has anyone fixed the gearbox on auger from leaking? mine leaks gear lube everywhere i park it. I see the gasket is available. I was hoping to be able to fix it on the blower and not have to pull the augers and the 2nd stage blower. Thx Todd Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #2 Posted January 13, 2017 aboard to , sorry but yes you have to basically tear completely apart and while your at it a good time to check and replace the bronze bushings on the auger shaft ends the bearings on the impeller shaft the gear/sprockets and chain on the impeller drive ect, as for the leak it's more than likely the 2 flat oring seals on the auger shaft in the gearbox than the gasket and the factory replacement isn't that good, as I did this rebuild in the fall of '15 I found some industrial seals/orings which I think are better, also there's bronze bushings in there too which may be worn as well, good luck,Jeff. 1 Share this post Link to post Share on other sites
