Agage1
Kubota
Agage1
What are y'all s thoughts on the Kubota b5200. I just got a great deal on one. 4wd, loader, bush hog, and only 600 hrs! Never had a Kubota, anything I should look out for? So far I've heard all good things
Achto
Kubota's are great little tractors. They only have two issues to my knowledge.
1 being that I've yet to see a Kubota engine that will start good the first time of the day without using the glow plugs, out side temp does not matter. OK so this is really more of an annoyance than an issue. I just don't think you should have to use glow plugs when it's 70+ degrees outside.
The second thing is the pinion gear on the front axle, this has been know to strip out. This issue can be avoided by not ramming the bucket into things while in 4wd. If you ease into things you should never have a problem with it.
shallowwatersailor
Check out these sites for information. The second one seems to have a hit-limiter per month so becomes unavailable late in the month.
http://www.orangetractortalks.com/
http://www.kubotabooks.com/
