HeyMrP
Newbie here and just got a 310-8
Walt
:WRS: that thingy would be the mule drive.
AMC RULES
:WRS:
953 nut
:text-welcomeconfetti:   to :rs:  looks like a nice package deal there!     :text-coolphotos:
JAinVA
Nice score.Good maintenance and the knowledgable folks here will keep it going for many years.Luck,JAinVA
SylvanLakeWH
Sodaking27
Congratulations. My first wheel horse was a 310-8. I still own one.
Ed Kennell
:text-welcomeconfetti: to the :rs:          You came to the correct site for :wh: information.     Search our manuals section for information on your tractor and implements.
BTW, see if you can find the correct routing of the snow thrower drive belt.   Here is a picture.  And, yes this belt has been replaced.
Texas Todd
:text-welcomeconfetti:to :rs:
Terry M
6wheeler
:text-welcomeconfetti:to:rs: Congrats on the 310-8. You will like it. And since there is no point putting it off? I, just happen to know where you can get another one just like it:banana-blonde:. Because, as you will soon find out? One is never, ever, ever, going to be all you will have. Just saying :ROTF:.
HeyMrP
My gut told me that something was wrong. It just didn't look right. Thanks!
  • Like 4
Achto
:WRS:  Nice score!
jimkemp
:text-welcomeconfetti:A lot of great info on this forum , have fun , look around , and think about becoming a supporter of the forum
HeyMrP
Had to swipe a spring from the kids trampoline. Does that look better?
  • Like 4
Ed Kennell
Bingo!!!!
HeyMrP
24 minutes ago, Ed Kennell said:
Bingo!!!!
I see yours has a worm gear that spins the discharge chute. Mine has a winding cable setup that feels sticky and catches. I think I'll take the chute off, clean out gunk, lube where it seems right to lube, and see how it goes.
...and I was just looking at the manual and I see that there is a lift assist for the blower. Gonna have to get that!
Edited by HeyMrP
added info
benji756
:text-welcomeconfetti: tall chute snow blowers have the worm gear adjusters and the short chute ones have the not so great cable set up
KC9KAS
@HeyMrP :text-welcomeconfetti: to :rs:
T-Mo
Nice tractor setup you got.
953 nut
Contact Glen Pettit, he is a Vendor on here and as nice a guy as you would ever want to deal with, fix you right up
Notfishin
Only thing i can Say  is . clean the garage up . because these things breed like rabbits . LOL
T-Mo
They do seem to multiply rapidly.  I am even considering of adding another shed to house some tractors and other stuff......
Ed Kennell
Yeah, the "tall chute" blowers have the gear drive chute rotator and it dies work better than the cable drive.
  Although I have had both and with proper maintenance, the cable drive works OK.
I see yours has the larger dia. spool on the cable crank.  That is a plus, as the earlier models just wound the cable around the 1/2" dia shaft.
Some have had success using heavy string trimmer line instead of the wire cable.
  I have all hydraulic lifts now, but when I had manual lifts, I had a 3 spring assist on my blower that really worked well.
My springs were made from old broken garage door springs.    Just another option if you like to DIY.
T-Mo
I have a helper spring off a John Deere 110 round fender that I thought about trying to use on my 416-8 somehow.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Looking for the OEM nelson muffler that fits the Kohler Magnum M10 thru M16 engines found on the following tractor list:
      310-8
      310-H
      312-8
      312-H
      314-8
      314-H
      410-8
      410-H
      412-H
      412-8
      414-8
      414-H
      416-8
      416-H
      and also and "A" models that had the kohler magnum.
      I dropped mine off to be welded and it came up missing.  It was not good to begin with so im sure they accidentally tossed it out with the way it looked.
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
