tractor girl 58
1977 B 100 Automatic won't start
tractor girl 58
I have a b 100 that I am trying to get started.  It will turn over but will not start.  Just replaced the spark plug with an autolite 216 and picked up a tester at the same time.  The tester appears to have zero spark. I pulled the solonoid and cleaned all the connections, still won't start.  What are acceptable replacement parts for this?  Can I use the ford tractor 12 v solonoid and coil from TSC?  What part would be the most obvious to try first?  As a side note, I also drained all the gas and put fresh in yesterday just in case..
SylvanLakeWH
I would start obvious and cheap. You just replaced the gas - Are you sure its got gas at the end of the fuel line? I've spent some time over the years pulling cords on engines where I had forgotten to turn the valve back on or didn't prime it long enough...May just not be getting any gas...
I would also double check every connection - may have dislodged something when you changed the plug...
Good luck!
squonk
Check to make sure you have 12 volts to the plus side of the coil with the key on and in the cranking position. Get a 12 volt test light or an analog multimeter to check this. Both available at TSC. If you have 12 v there Use either tester and test the Negative terminal of the coil. While cranking the light should blink or the meter needle should swing back and forth. If neither tester does this, the next step is check the points for making and breaking of the coil primary circuit. You need to break the current flow in the coil primary to create the high voltage in the spark plug circuit.
tractor girl 58
Thanks SylvanLakeWH,
What's the best way to ensure it does have gas at the end of the fuel line?  I will go back and double check all connections.  Tks
Hi squonk
I have a multimeter so I will check as suggested.  My problem is trying to diagnose at the engine while sitting in the seat. The safety under the seat is overridden but the clutch has a safety also so I can not figure out how to not be in the seat and diagnose at the same time ..
I also tried to buy new points and condenser last night but the auto store didn't have a clue how to find what I need.  Are there current standard replacement parts that work on these older models?
SylvanLakeWH
I would disconnect the fuel line at the carb.
tractor girl 58
learning as I go,,  that sounds like something I can find without difficulty :D
rmaynard
I'm confused. You mentioned that you have no spark, yet you said that you cleaned the connections on the solenoid. The solenoid has nothing to do with spark. The solenoid controls the starter. So, does it turn over?
clueless
:text-yeahthat:
953 nut
:WRS:      Troubleshooting a dead engine can be frustrating, but we are here to help. This manual should be helpful.
The ignition points and condenser are a standard Kohler item, not specific to :wh:. As others have said, the solenoid has nothing to do with the ignition system, if it is cranking over from the key switch it is fine. Remove the spark plug and with the plug wire connected to it place it on the engine head where you can see it and crank the engine to see if you have spark. Let us know how you do with fuel and spark.
tractor girl 58
Sorry, that goes back to my learning as I go.  So, note to self, solonoid = starter, nothinh to do with spark..
When I turn the key it just churns, it does not catch aka start.
I picked up a coil at TSC that  "looks" just likeine but o know it may be witlred completely different inside, grabbed it just in case it was compatible.
So what should I try next?
Thanks 953 nut, I'll give fuel and spark a shot and report back later .  Appreciate everyone's help !!
rmaynard
The clutch safety switch is only there to prevent you from actuating the starter. So, with help if possible, spray a little starter fluid into the carburetor while cranking the engine. If it starts briefly, you have a fuel delivery problem.
KC9KAS
She said NO SPARK....
Make sure the points are clean and adjusted correctly. @953 nut posted the manual for your tractor to help with the cleaning/adjusting.
These tractors are fairly simple to fix and get running, but we (me and others) do not always understand what we are trying to troubleshoot from the easy chair.
Pull up the manual(s) and read through them, then read them again while looking at your tractor, THEN read them again while working through the process.
Do not get discouraged, as we will work this out, you will understand what we are trying to say, and we will understand your problem.
Red Square members have fixed many, many tractors over the years from hundreds of miles away.
@tractor girl 58Oh, and :text-welcomeconfetti: to :rs:
  • Like 5
tractor girl 58
Thanks KC9KAS, appreciate the understanding and support..  I'm heading to the garage now with the manual and will report progress as I make it..
rmaynard
@KC9KAS You are correct. She did say that her tester showed zero spark. However, I have seen on my own tractors where what I was sure was a "no spark" condition actually turned out to be a no fuel situation. You might say that I am just adding "fuel for thought".
tractor girl 58
so one last question before I head out,, what do I need to take off to get at the points?  I can't seem to find that answer in the manual or via google..
KC9KAS
@rmaynard I just wanted to make sure she used the manual and worked through it.
Also did want her to give up on us and the GT!
In the front of the engine to the left of carb (looking from the front) and low there is a 3-4" cover. There will be a wire going into the cover. A medium sized straight blade screw-driver to remove 2 machine screws. Unless someone changed them to Phillips head screws!
Texas Todd
rmaynard
And if you have the original stock muffler as pictured above, getting the screws out can be a challenge.
Texas Todd
Ed Kennell
All good advice above,   But when I am trying to start a non running tractor,  my first step is to get it turning over properly, then verify I have a good spark at the spark plug, then try to start it by squirting fuel directly into the carb,  and lastly remove the fuel line at the carburetor and check for a good spurting fuel supply to the carb.
If the engine isn't turning over properly or if there is no spark at the plug, no amount of fuel delivery  maintenance will start the engine. :twocents-02cents:
  • Like 7
tractor girl 58
Ok, just finished up and here's the recap.
Fuel supply good at carb
multimeter  registers 12 volts on positive side of coil with key on
multimeter registers good resistance through plug / coil wire
multimeter registers on negative side of coil while cranking
NO spark when laying spark plug on engine while attached to coil
not sure what if anything this indicates but accidentally left the key on from prior step and while looking at the points got a spark from the bottom screw.
couldn't feel my fingers any longer so didn't go any further with the points testing tonight.
will read all the new comments and see what I have missed for testing and will try again..
benji756
possible bad spark plug wire?
gwest_ca
If you have a steady 12 volts in this last one that is your problem.
When the points are open you should have 12 volts.
When the points are closed you should have 0 volts.
If it does not go to 0 volts the points are not closing to make an electrical connection or the contact surfaces are oxidized and not making electrical contact. Clean the contacts with a point file or nail file and then drag a strip of white paper through the closed contacts to clean them.
The points open once for every 2 rotations of the crankshaft so when cranking you should see the coil (-) voltage go from 12 to 0 once every 2 rotations. At cranking speed a test light will also show this changing voltage. Once you get that it should run.
Garry
953 nut
  On 1/8/2017 at 3:14 PM, tractor girl 58 said:
You may not see the change in voltage Garry is talking about on a digital multi-meter at cranking speed, try this with the key on and turning it by hand  (PTO engaged will let you turn it from that side).
tractor girl 58
thanks all,  I will try the suggestions after work today.
tks
  • Similar Content
    • Mattgray
      By Mattgray
      I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
    • TailGate18
      By TailGate18
      Need help please
      Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
      I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
      The mower itself all I could find was one tag on the frame under the gas tank.
      ID # 61-08K801-05782
      Then under that 4 digits
      6337
      Has a Kohler motor info as follows
      Model-K181
      Spec- 30538
      Displ (cc)- 305
      Serial #- 2613800539
      It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
      Says it's a B-80 8 speed
      Thanks in advance
    • nickjet67
      By nickjet67
      Hello all, I recently acquired a "new" B-115, and with the help of @ohiofarmer, I will be fixing her up, first with a engine he is trading me for my old Kohler engine off my '77 B-80 that I trashed when I was 13. I haven't been in the Wheel horse game long, as I am 16 now, I hopefully will be able to keep this project updated on here, especially in the spring when I will be completely repainting it! I am super excited for this project, and am ready for all the challenges that lay ahead with it. if you have any helpful information you are willing to share about my newly acquired project, please share! I haven't had tons of luck finding tons of information about it.
    • nickjet67
      By nickjet67
      Hi, been a while since I been on the forum, but I needed to log on to get some help with my "new" b-115 I picked up for $25! I saw this beauty sitting on the side of the road and I just needed to have it. only issue is it doesn't have a engine and the steering was all discombobulated. Last night I got that all welded up and now I am looking for help, I need to get the Briggs motor that came on it now, I have had 0 luck with finding the right motor for it but I have found almost every part I would need to build one from scratch. They are all over ebay and craigslist (the parts) and would be expensive but nice. Any help would be greatly appreciated! (also am looking for a snow blower and a bagger for it, dont know if the bagger for it exists but would be nice to have.
    • dmhill
      By dmhill
      Does anyone know what drive belt and deck belt I need for the 1980 B 82? Also if anybody had pics of the drive belt installed I would appreciate it.....
      When I picked it up both belts were/are missing. Not entirely sure all the necessary hardware is under there either, however, it seems complete. Thank you in advance.
