briankd
front tires
peejo50
On 7/18/2023 at 4:08 PM, 123GO said:
Been meaning to post pics with mine on my 414-8 for a yr because this post really helped me out. Triple bypass in Jan got in the way of posting my Triple Rib tias....lol
  These are Deestone 4:00-8 on 4" rims? May be 3.5" rims but old WH rims made for 4:00 tire with tapered bearings if that helps any. Done forgot actual rim width sorry all. 4" is my bet, Lordy Lordy I think I'm an old fart folks.
 Well no more sliding around slowing my old arse down, Im safer cruising on high now..lol. Well high sometimes, I really sped her up substantially..so hit high you hang on tight, yeehaw!
Grip is just fantastic on my hills with tri-ribs, I highly recommend them. Best part its just like having power steering man!
If you suffer from upper extremity issues like myself, this is your answer! They don't call them "Easy Steer" for nothing that's a fact.
Good Looking Horse!
peejo50
On 1/1/2017 at 6:50 PM, briankd said:
need to get new tires for front of my c-120 it currently has original turfs on it and they are shot. I can't make up my mind what tire to put on it .  any suggestions and past experiences anyone had on here? it currently has firestone ags on the rear was looking at vredestein  5  rib tires then the super turf and the regular rib tires (they are the smoother rib ones) tri ribs don't think I really  care for. going to use this tractor plowing dirt some snowblowing (if we ever get snow) and some mowing
it has 16-6.50- 8 on it could  a wider tire fit these rims? 7.50 or a 8.50?
                                                   Thanks Brian
Picked up a set of tires from Priority Tire for my C-120 at a great deal. In and out of stock but keep checking.
