chev0545
wheel weights
chev0545
how long should all thread be to mount weights? standard wheels ( 416 & 520 ) plastic covered wh weights
thanks
Edited by chev0545
Sparky
To vague a question, it would depend on the rim offset and rim width. Also I have some cast weights that are flush with the rim...I've seen the plastic ones that stick out a couple inches. All these things affect the bolt lengths.
 Edit your post or at least add what rims and what weights your using.
  Mike.....
T-Mo
On a lot of my wheel weights, I used 1/2 inch threaded rod and then cut them to the length I need.  Be sure you use lock nuts on the inside of the rims with either lock nuts or split washers on the outside to prevent a nut from backing off and causing some problems.  Don't ask how I know.:(
I went to tractor supply and bought 10 inch 5/8 carriage bolts for the plastic weights then put double nuts on the out side then I took my grinder with a cut off wheel and cut of even with the out side nut worked for me.
  • Like 7
JERSEYHAWG /  Glenn
I have had plastic and cast weights on various rim sizes, what fits one normally doesnt fit the other. 10 inch bolts and a hacksaw solves all the problems.
Glenn
  • Like 4
Tankman
TSC pricing on zinc coated carriage bolts is excellent.
Why not push the weight to the wheel and measure the required length?
While we're at it, although I have steel and plastic weights, easy 'enough to make some using discarded brake drums.
  • Like 6
Joebag
 I gotta find a way to make me a set of wheel weights my 876 has a set of 23 turf tires on it.
