Mike'sHorseBarn 3,132 #1 Posted December 28, 2016 So I have been messing with this 753 off and on for months now trying to get all fixed up mechanically. When I first got it, it leaked gas horribly out of the carburetor, but I found out it had the wrong bowl on it and didn't seal properly. Fixed that and put a carb kit in it and now nothing works. The carb always floods out. So I put a new float in and adjusted to 11\64 gap, cleaned the carb really good and readjusted to factory specs. Same problem. What am I doing wrong? Share this post Link to post Share on other sites
prondzy 3,883 #2 Posted December 28, 2016 Why 11/64th? Im guessing your float is not closing the float needle. Share this post Link to post Share on other sites
Hacksawhero123 351 #3 Posted December 28, 2016 With the bowl off, turn the carb upside down. With only gravity letting the float rest on the needle, the float should be parallel to the oring land of the carb body. Every carb manufacturer gives a measurement, but it basically sets it just as I described. Doesn't matter if it's a mower or a 4 carbed Japanese drag bike, it's all the same. Double check that your float is not getting fuel leaking inside. I had two Kohlers here at the same time with bad floats. Also make sure that you're needle is not too short. I've gotten kits with multiple needles and even wrong needles. Good luck. Mark. With the bowl off, turn the carb upside down. With only gravity letting the float rest on the needle, the float should be parallel to the oring land of the carb body. Every carb manufacturer gives a measurement, but it basically sets it just as I described. Doesn't matter if it's a mower or a 4 carbed Japanese drag bike, it's all the same. Double check that your float is not getting fuel leaking inside. I had two Kohlers here at the same time with bad floats. Also make sure that you're needle is not too short. I've gotten kits with multiple needles and even wrong needles. Good luck. Mark. Dumb question, is it flooding out when running, or is fuel pouring out when the fuel turned on? If only when running, make sure the main jet needle doesn't have the tip broke off. Mark. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,132 #4 Posted December 28, 2016 (edited) 32 minutes ago, prondzy said: Why 11/64th? Im guessing your float is not closing the float needle. That is what my kohler book says to set it at. I have messed with closing it more to make the fuel shut off sooner and get the same effect. 12 minutes ago, Hacksawhero123 said: With the bowl off, turn the carb upside down. With only gravity letting the float rest on the needle, the float should be parallel to the oring land of the carb body. Every carb manufacturer gives a measurement, but it basically sets it just as I described. Doesn't matter if it's a mower or a 4 carbed Japanese drag bike, it's all the same. Double check that your float is not getting fuel leaking inside. I had two Kohlers here at the same time with bad floats. Also make sure that you're needle is not too short. I've gotten kits with multiple needles and even wrong needles. Good luck. Mark. With the bowl off, turn the carb upside down. With only gravity letting the float rest on the needle, the float should be parallel to the oring land of the carb body. Every carb manufacturer gives a measurement, but it basically sets it just as I described. Doesn't matter if it's a mower or a 4 carbed Japanese drag bike, it's all the same. Double check that your float is not getting fuel leaking inside. I had two Kohlers here at the same time with bad floats. Also make sure that you're needle is not too short. I've gotten kits with multiple needles and even wrong needles. Good luck. Mark. Dumb question, is it flooding out when running, or is fuel pouring out when the fuel turned on? If only when running, make sure the main jet needle doesn't have the tip broke off. Mark. It floods out when I try to start it. Edited December 28, 2016 by Mike'sHorseBarn Share this post Link to post Share on other sites
Hacksawhero123 351 #5 Posted December 28, 2016 So fuel is running out of the carb body when you spin it over but it doesn't run out just sitting there? Are you running a fuel pump or gravity feeding the carb? Share this post Link to post Share on other sites
Mike'sHorseBarn 3,132 #6 Posted December 28, 2016 26 minutes ago, Hacksawhero123 said: So fuel is running out of the carb body when you spin it over but it doesn't run out just sitting there? Are you running a fuel pump or gravity feeding the carb? Fuel pump Share this post Link to post Share on other sites
Hacksawhero123 351 #7 Posted December 28, 2016 (edited) If the float is adjusted properly and is air tight (no fuel inside the float, take it out and shake it, make sure no fuel is sloshing around in there), and the needle is proper, then something is holding the needle open. Take a wooden match stick and with gentle pressure, spin the matchstick into the needle seat to make sure there is not a burr or trash holding the needle open. After lapping the seat with the match, you should see a bright shiny ring on the seat. Edited December 28, 2016 by Hacksawhero123 3 Share this post Link to post Share on other sites
Shynon 7,475 #8 Posted December 28, 2016 Needle is not closing, either a bad carb kit or you have a pin hole in the float. Take the float out and shake it and see if you hear anything inside it, or submerse it and look for bubbles. Share this post Link to post Share on other sites
953 nut 57,896 #9 Posted December 28, 2016 9 hours ago, Hacksawhero123 said: bowl off, turn the carb upside down. With only gravity letting the float rest on the needle, the float should be parallel to the oring land of the carb body. At this point put a snug fitting piece of plastic tubing into/over the fuel inlet fitting and blow gently (2 or 3 PSI) into it. If the needle and seat are good there will be no air movement. If there is any blow by then replace them! 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,132 #10 Posted December 28, 2016 1 hour ago, 953 nut said: At this point put a snug fitting piece of plastic tubing into/over the fuel inlet fitting and blow gently (2 or 3 PSI) into it. If the needle and seat are good there will be no air movement. If there is any blow by then replace them! I hope that is not the case since it is a new needle and seat, but if it is I guess that's why i keep kohler carb kits in stock in my garage lol I will definitely give that a try! Share this post Link to post Share on other sites
Sarge 3,464 #11 Posted December 28, 2016 Might want to check the fuel pressure - that pump may have lost it's ability to regulate the pressure and is pushing far too much . I run a return loop with a bypass filter when I use an electric pump to prevent this issue and make the pumps last much longer . See the thread in the tractors section under "crank 20 times to start Kohler"... Sarge Share this post Link to post Share on other sites
Mike'sHorseBarn 3,132 #12 Posted December 28, 2016 45 minutes ago, Sarge said: Might want to check the fuel pressure - that pump may have lost it's ability to regulate the pressure and is pushing far too much . I run a return loop with a bypass filter when I use an electric pump to prevent this issue and make the pumps last much longer . See the thread in the tractors section under "crank 20 times to start Kohler"... Sarge Can that happen on a mechanical fuel pump? Share this post Link to post Share on other sites
Sarge 3,464 #13 Posted December 28, 2016 Generally , no - especially a factory pump . I thought I read in this thread you were using an electric - my mistake . Sarge Share this post Link to post Share on other sites
Achto 28,777 #14 Posted December 28, 2016 15 hours ago, Mike'sHorseBarn said: cleaned the carb really good and readjusted to factory specs. Did you also clean the vent passage from the bowl to the throat of the carb? If this is plugged gas will be forced out through the main jet as it is pumped into the carb. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,132 #15 Posted December 28, 2016 Just now, achto said: Did you also clean the vent passage from the bowl to the throat of the carb? If this is plugged gas will be forced out through the main jet as it is pumped into the carb. Yep, did that. Share this post Link to post Share on other sites
Achto 28,777 #16 Posted December 28, 2016 9 minutes ago, Mike'sHorseBarn said: Yep, did that. Was a thought, I had it happen to me once. Share this post Link to post Share on other sites
