Duramax7man7
Is this used 60" Blade worth it?
Duramax7man7
Is this used blade worth the $75 asking price? Maybe get them down another $10- $15 make it worth it?
My 42" is beat up!? I should be able to mount this right to the frame, no?
gwest_ca
Don't see a 60" blade but the D-250 10-Speed models used one advertised as 59".
Copy and paste this with the quotes into the search box and then select Files.
"Blade Dozer 59in"
Garry
squonk
What tractor are you going to hook it to? The bigger the blade and it's more power and weight needed to push and lift it.
Edited by squonk
daveoman1966
It is, after all, only money...so.................................
.buy it.
Duramax7man7
I was going to hook it up to my 312-8 with 105lbs of wheel weights and chains... We don't get a ton of Snow so its not like I would be moving a ft worth at a time.
.buy it.
Not 100% sure how to take this.. ha ha.
Ed Kennell
It doesn't look WH to me.   Looks like the PO altered it to fit his frame.   If you can weld, you could do the same.
Duramax7man7
Yeah I wondered about the way that it was really rippled in the blade in comparison to other WH blades I've seen.
 You can almost bet that this is a 59" blade but they marked it 60" to sell it.
