Countdown To Christmas!
rdeanrj58
Tecumseh wiring
rdeanrj58
I have a Tecumseh electric start engine HH 60  105125J    ser. 4342D that I am attempting to put in a 552.   I don't know what the engine came from ... bought it at a flea market.    I'm trying to figure out how to wire it.   There is a quick connector with 2 wires .... one comes from stator the other goes to coil.  Do I need a voltage regulator?  Amp or volt gauge?  I plan on using a key switch and a starter button as I believe that's what it originally had.  Any help would be appreciated
gwest_ca
Found a parts list. The 3rd page shows a diode in the harness so a regulator is not needed.
https://www.partstree.com/parts/tecumseh/engines-horizontal-4-cycle-engine/hh60-105125j-tecumseh-4-cycle-horizontal-engine/
Garry
Adding
You could use an ammeter but it won't show much because of the low output of the stator. A voltmeter would be nice but you have no way of turning it off and you don't want that. You could go from the diode straight to the battery + post.
Wiring diagram in the operator manual
rdeanrj58
Oh so I already have the diode.  It's inside the sheath just before the connector.     Thanks Garry
KC9KAS
@rdeanrj58 :text-welcomeconfetti: to :rs:
JC 1965
Hello and  :WRS:
  • Similar Content
    • CasualObserver
      By CasualObserver
      1962 Wheel Horse sales mini brochure. Original is only 1/4 size of regular paper sheet.
      Full size
      10 pages 1.8MB
    • Hukah
      By Hukah
      I just put a 'Stens' universal ignition module on my SB-421.
      Its finally showing a spark, but it's faint.
      Ohmed out the mag and found it's shot (42,000 ohms).
      I guessing the points/coil and mag went at once?
      Since it appears the universal is working, i'm looking for a magneto for this model, if anybody has/knows of one.
      Since I bought two universals, I'm looking to attempt to see if one will work on my 552/H55 engine.
      Has anyone done this on the diode system yet?
      (I posted this on "engines" board also)
    • tgriffin27
      By tgriffin27
      My GF found this for sale while travelling and it is 160 miles from me so I can't go and look at it till saturday. From youtube videos I have watched I think it is a 552. The owner bought it at a fleamarket last year and has been using it as yard art since then. He says it doesn't steer(you turn the steering wheel and the wheels don't move) and the engine doesn't run(he has never tried to start it since he has owned it. From the pictures can you guys tell what it is and what should I be looking for when I go see it(any problems with these models or parts it should have? He is also asking $300 obo so what would you guys offer knowing it needs a total restoration and may be missing parts? I don't know wheelhorse lawnmowers at all but I love the look of them and want to own and restore one.
    • JerDecker63
      By JerDecker63
      I recently pulled this Wheel Horse out of my Father-In-Law's garage. He said that he picked it up some years ago at a yard sale.  I am interested in getting it running again but as can be seen from the pictures the carb is missing.  I am not having any luck surfing the web trying to figure out where to get parts.  My Father-In-Law said that the engine ran but he pulled the carb for another project and never got back to this one.  If anyone could help point me to a service manual I would greatly appreciate it.
      Muffler will be needed once this thing gets fired up!!
    • spenc
      By spenc
      I can not find a wiring diagram for my 1962 wheel horse it has a key and a button u push to make the electric motor turn. It has a kohler k161s
