WHX?? 49,874 #1 Posted December 20, 2016 Picked this up yesterday, not like I needed another project but the price was right and always wanted a FEL on a compact tractor. Supposedly has a 2 cylinder, 15 hp. Is 4wd too. Haven't had any time to delve into it yet, way too cold outside to work on it and no room in the shop! Been told it has a mower deck that goes with it that is buried in the PO's shed for retrieval in the spring. Nother thing I though was strange as it has rear pto that has three speeds?? 12 Share this post Link to post Share on other sites
pacer 3,174 #2 Posted December 20, 2016 NICE!! I have a Mitzi just a bit larger, 4wd & FEL ... but I would have preferred that sized one you got. Mine has the deep tread depth lug tires and boyoboy is that thing a bear to steer! Parts are like WH's and can be hard to find, although I have found that there is some crossover in brands - Yanmar for one on a couple things. 1 Share this post Link to post Share on other sites
WHX?? 49,874 #3 Posted December 20, 2016 Thanks Pacer... for what little seat time I've had it steers pretty good. Front tires are about shot and was maybe thinking ags ....maybe not then! .. didn't want to hear about the parts thing tho! Share this post Link to post Share on other sites
Achto 28,164 #4 Posted December 20, 2016 43 minutes ago, WHX9 said: Nother thing I though was strange as it has rear pto that has three speeds?? OK, 540rpm-common, 1000rpm-common, & what's the third speed? Looks like it could be a handy lil tractor Jim. 2 Share this post Link to post Share on other sites
WHX?? 49,874 #5 Posted December 20, 2016 I've never heard of anything more than 540, PO just dropped off the service manual this morning so will have to look into it Dan. 4 minutes ago, achto said: Looks like it could be a handy lil tractor Jim. Yes I'm thinking some forks for moving logs, grab hooks on the bucket, lots of possibilities. 2 Share this post Link to post Share on other sites
Achto 28,164 #6 Posted December 20, 2016 On farm tractors 1000rpm shafts normally have a finer spline on them. Will be interesting to hear what the speed options are on it. I will have to pick a day to stop by and check that thing out. For cutting wood a FEL is extremely nice to have. We rarely go out to the woods without taking our Ford 871 along. 3 Share this post Link to post Share on other sites
Wishin4a416 2,191 #7 Posted December 20, 2016 Nice looking machine Jim. I have never seen one in this area. Any FEL is worth there there weight in gold to me at my age. Back is shot. Good Luck!! 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #8 Posted December 20, 2016 Jim, my old WH dealer also sold the Satoh/Mitsubishi tractors before Mitsubishi was wrangled out of making their own tractors when using their engines in a major US brand (I can't recall this moment) they were/are solid little machines, and Ags and turf tires on different rims were all that was available before R4s, when they came out with 3cylinder versions they had a front mounted rotary mower for them, I believe you'll have yourself a fine little loader tractor there,Jeff. 1 Share this post Link to post Share on other sites
AMC RULES 37,144 #9 Posted December 20, 2016 Nice score... pretty cool little tractor. 2 Share this post Link to post Share on other sites
ACman 7,629 #10 Posted December 20, 2016 ... a true scut , you should enjoy that tractor . It looks like International/Cup Cadet used Mitsubishi for some there scut's . That was from tractordata , but it looks like there's places on the net to get new and used parts . 2 Share this post Link to post Share on other sites
WHX?? 49,874 #11 Posted December 21, 2016 It looks like Jeff @WVHillbilly520H hit the nail from with what I read in the manual last nite about the pto. Bonus, it did come with a fairly comprehensive service manual. But no IPL or operators manual. Not that we can't figure out how to operate it just one of those nice things to have. If you run across those sites @ACman don't be shy about saving me some leg work and post a link here! My research has pretty much come up empty so far but haven't tried real hard. Did get it into the shop last nite and has a few hydraulic leaks but nothing that can' be repaired. Looks like it has a lever for locking up the rear diff. but haven't figured that out yet. Got some other strange PO stuff goin on that can't quite figure it out. Will probably fix the easy stuff and then have to get our area tractor pro @achto over for some beers & BS to clarify a few things & school me! Sure wish it was power washing weather as it needs a good bath....oh well spring is coming! You can't even look at it with out getting your hands full of diesel snot....! Good thing I enjoy getting my hands dirty! 23 hours ago, achto said: shafts normally have a finer spline on them by the way Dan book said this has the standard SAE 6 or 8 spline ... don't remember the count. Share this post Link to post Share on other sites
Achto 28,164 #12 Posted December 21, 2016 32 minutes ago, WHX9 said: You can't even look at it with out getting your hands full of diesel snot....! Diesel is my favorite cologne! 34 minutes ago, WHX9 said: Dan book said this has the standard SAE 6 or 8 spline Imports some times have their own way of doing things when compared to US manufactured tractors. Some US tractors will have both 540 and 1000rpm shafts exposed for use. On a JD 4020 I know you have to get some wrenches out to switch between the two different shafts, (about a 5min job). If you have the standard SAE 540 shaft it should be fine for most domestic attachments you may acquire for that size tractor. The only 1000RPM implements I've ever used are a forage chopper and a side sling manure spreader. 1 Share this post Link to post Share on other sites
WHX?? 49,874 #13 Posted December 21, 2016 Oh yeah Dan.... dab behind the ears.....that's gonna make ya a chick magnet!! 1 Share this post Link to post Share on other sites
Achto 28,164 #14 Posted December 21, 2016 It always gets my wife pretty excited when I come in the house smelling like diesel. I hardly get in the door & she demands that my cloths come off. Works every time! .......Of course then she says "Put them in the washer and go take a shower!" 5 Share this post Link to post Share on other sites
WHX?? 49,874 #15 Posted December 21, 2016 23 minutes ago, achto said: and go take a shower!" alone 1 Share this post Link to post Share on other sites
Olratlr 25 #16 Posted December 21, 2016 I thought you guys would like to see the Satoh Beaver I picked up about 6 years ago and restored. It is almost like your 372 Jim I wish mine had a FEL though. 4 speed low high tranny Diesel 4 wheel drive 7 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #17 Posted December 21, 2016 (edited) @Olratlr,wonder if you had good pics (along with dimensions) of the "cool" Beaver decals if Terry the vinyl guy could duplicate a set for you? I know dad still has a dealer's brochure somewhere at with the "Beaver", "Stallion", and "Elk" if not more versions of the Satoh line...this size kinda looks like a mix of WH 520H and 4x4 hybrid with snow plow,Jeff. Edited December 21, 2016 by WVHillbilly520H 2 Share this post Link to post Share on other sites
WHX?? 49,874 #18 Posted December 21, 2016 Yes very similar and VERY nice resto on it!! Muffler style is identical. I have the throttle on the side of the dash and a foot throttle as well. From my limited research so far it appears they were made from '82 to 88?? Mine must be more toward the late models considering the square headlights?? It appears mine did have the ambers on it ...at one time I'm sure Terry could make the correct decals and it sure wouldn't hurt to ask him! Few things different there Jeff But def. the same base tractor. And herein lies the problem...you turkeys come along with these nice restos and now I think mine has to look like that and Dan's Cockshutts!!! I have two-stagers to fit up and this is posed to be a working tractor! 2 Share this post Link to post Share on other sites
WHX?? 49,874 #19 Posted December 21, 2016 If anyone is interested in a mower that may fit up to one of these There was supposed to be with it and will be in spring. I have yet to lay eyes on it but have the manual. I believe it is a Woods...does that sound right? Driven off a electric??? front pto. I got six mowers now and the FEL has to come off to mount it. will prolly never use it and would let it go for a song, a prayer and a 12 pak. 1 Share this post Link to post Share on other sites
ACman 7,629 #20 Posted December 22, 2016 (edited) I learned something today ... how to post a link here you go @WHX9 says they're the only factory authorized Mitsubishi/Satoh parts dealer in the USA . http://www.pittauto.com/default.aspx?page=customer&file=customer/piauel/customerpages/pl_mitsubishi.htm Edited December 22, 2016 by ACman 1 Share this post Link to post Share on other sites
WHX?? 49,874 #21 Posted December 22, 2016 interesting Jeff & thanks... from that site They sold their own tractors using the Mitsubishi brand name in the USA in the 1980's. Mitsubishi purchased Satoh in 1980 and marketed many Mitsubishi tractors that were branded Satoh. Finally, Mitsubishi has supplied certain models of tractors to many manufacturers including Cub Cadet, Mahindra, Bolens, International Harvester, and Case. Was another link ther to Satoh brand for you history buffs.... 1 Share this post Link to post Share on other sites
wheeliedude 3 #22 Posted December 27, 2016 I have been looking high and low for a 4 wheel drive garden tractor. I have seen dozens of brands, mostly Japanese imports from the 70's, 80's and early 90's. I was trying to get info on Gutbrod who built the D-250 for wheel horse, but have yet to find Gutbrod 2600 DA 4 x 4. I would like to find any brand of 4x4 about 20 HP diesel in need of work, engine blown etc. I live in S.E. MN. and have been trying to find one of these tractors maybe tucked out in the barn, or just sitting in the shed. The mits you have is very nice. You guys all do a great job of restoring your equipment. I would like mine with a loader, and belly mower. I have looked in just about all the major cities on Craigslist, and tractor auction sites. Share this post Link to post Share on other sites
WHX?? 49,874 #23 Posted December 27, 2016 Hey Wheelie dude, good luck on your search for that compact as they are not easy to find. Yes most older are Japanese imports but now the Chinese have taken over the import market. I see lots of older JD's for sale but they generally want too much for what shape they're in. 20-24 hp is what I had in mine but when one like this falls in your lap you almost have to take it. I see you are from Owatonna...MN I presume?? We have quite a few members in the Owatonna/Medford area. Hooking up with them at the Pioneer Power show is always a must! BTW Share this post Link to post Share on other sites
