ti-jean
Snowthrower lift spring question
ti-jean
Hi after blowing snow today ..I look under the tractor and a spring was hunging, it was the lift rod assist spring it was attache to the lift rod i cant not figure where is suppose to attache my blower is 0644sc01
thank for help help
gwest_ca
Manuals help?
Garry
pfrederi
It hooks over the 3/4" shaft that the brake clutch work on
ti-jean
 thank Garry I already have that manual the problem all the pics are dark it is hard to see where that spring gos I se on the lift rod ok but at the front very difficult .and to front hand is break any pics of that piece :unsure:
thank :thanks:
Edited by ti-jean
gwest_ca
This later one may be better. The model number changed but the product is likely the same.
Garry
Good drawing on page 8. Hope it is the same.
pfrederi
Sorry I was wrong I didn't notice you had a 2 Stage blower.
ti-jean
Wow ! this manual is greater then the one I got ...no problem I think the attachement are the same
thank
Edited by ti-jean
wallfish
The lift spring on my 2 stage doesn't connect to the lift rod. It connects from the blower frame up to a rod at the Tach a matic area on the PTO side. Mine is a hydraulic lift tractor so could be something else for a manual lift. :think:  There are only 2 springs on mine. That lift spring and the belt tension spring.
ti-jean
Ok Wow ! this manual is greater then the one I got ...Oh  I se I think the attachment are the same as a two stage blower
thank
Edited by ti-jean
