thehorse
Blower question
thehorse
After installing and using the
blower for sever years, I thought I had everything down to a science. I hooked blower up to 416-h a few weeks ago and moved to garage in preparation for snow. I had to move tractor around yesterday and when raising the blower, it sounded as if something was binding. After which, the blower will only lower to about an inch off the floor. I'm not sure if it was able to go the whole way to the floor before it bound up some. The gauge depth wheel is up and out of the way. Any ideas??
lynnmor
Sounds like you used the wrong hole.  Go back over the instructions and double check.
GlenPettit
Check your tire pressure also, the cold Winter air can drop it 2–3# easily, consider 20# in them (may give an extra 1/2" height).
Edited by GlenPettit
