tommyg
Rubber wipers for snowblower
tommyg
Several times I've seen posts about adding rubber "wipers" to the snowblower auger for better throw and to minimize clogging. Can someone enlighten me here? I think I know what you're referring to, but how would I know what to get, how big, how many, etc. Will this enable me to clean right down to the concrete? I'm using the blower for a D180.
Ed Kennell
These "wipers" close the gap on the single stage blowers.   I use pieces cut from an old rubber bed liner.  Some use flat belting.
The are put on both edges of the auger and they are custom cut to fit the clearance on your blower.  I back mine up with 1/16" steel.
  • Like 9
tommyg
Ahhh. I see what you're talking about now. Not was I was thinking after all. Thanks for the pic. So there's nothing special to buy, I'm guessing? Just a piece of maybe 1/4" rubber sandwiched under some sheet metal?
roadapples
I used a piece of sidewall from a front wheel horse tire. Cuts easily with a band saw, but there is a heavy wire were the bead seals. Ask me how I know...:bitch:
varosd
skrusins
I used the rubber from used paddle snow blowers. Your service centers trow them away.
tommyg
I have a piece of rubber flooring from the fitness center of the YMCA where I work. It's designed to endure heavy workout equipment and free weights dropping on it. Think I'm going to give that a try.
JERSEYHAWG /  Glenn
While we are on this subject, it can be done with the 2 stage also. I have seen pictures of it. I am considering that for next year, or maybe this year, job number 112 on job list ,,:lol:.  Any of you guys have a picture of that modification handy?
Glenn
Kurt-NEPA
Glenn
Glenn, I started out to do that on my two-stage.  I got the rubber and made some steel plate to hold it in place.  With a little care I was able to get the plate to housing clearance down to 1/16".  I called that good enough and never put the rubber in.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Brandon Byers
      By Brandon Byers
      I know I'm half a year ahead of schedule!
      I picked this 1974 D-180 up early last year. It had a pretty hard life, and the previous owner gave his best attempt at keeping it alive. Hydro was strong so I serviced it and put it to work mowing all year. I decided if it would make it through the season then it would get some TLC. By fall it was burning about a quart of oil an hour but it made it. I have no clue how many hours are on it, every hole, bushing, bearing on this tractor is pooched. If you look closely, somebody used two 1" NPT Pipe Flanges to rebuild the mounting points for the upper 3 point cylinder. Hey it works!
      I rebuilt the steering gearbox and re-bushed the front axle along with making new spindles.
      I had the 482 Kohler bored .20 over (it was .10 over already) and gave it a rebuild with the intention of putting it back to work on snow duty.
      I then dawned on me that this tractor will be 50 years old next year - and these old D's are becoming harder and harder to find anymore. So I decided to customize it a bit and go for what a maybe a dealership would offer for a 50th anniversary model if Wheel Horse was still in business today (In another universe, maybe!)
      As D's aren't known for their looks - and I can't leave anything alone. I took approximately 2 Inches out of the grille and bezel.
      I updated most of the wiring and lights. Gave it a new set of Carlisle Ags along with Vredestein front ribs. It got a new seat and I painted all the accents aluminum.
      I patched, rebuilt the 48" deck and put new blades, wheels, and hardware on it. The Blade & 3 point scoop somebody adapted to it also got some attention.
      Lastly I stripped it most of the way down and painted it with IH red acrylic urethane enamel.
      I always forget to take pictures during my projects but here's a few:
      Before:
      After:
      Thanks for reading!!
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
