tommyg
Rubber wipers for snowblower
tommyg
Several times I've seen posts about adding rubber "wipers" to the snowblower auger for better throw and to minimize clogging. Can someone enlighten me here? I think I know what you're referring to, but how would I know what to get, how big, how many, etc. Will this enable me to clean right down to the concrete? I'm using the blower for a D180.
Ed Kennell
These "wipers" close the gap on the single stage blowers.   I use pieces cut from an old rubber bed liner.  Some use flat belting.
The are put on both edges of the auger and they are custom cut to fit the clearance on your blower.  I back mine up with 1/16" steel.
  • Like 9
tommyg
Ahhh. I see what you're talking about now. Not was I was thinking after all. Thanks for the pic. So there's nothing special to buy, I'm guessing? Just a piece of maybe 1/4" rubber sandwiched under some sheet metal?
roadapples
I used a piece of sidewall from a front wheel horse tire. Cuts easily with a band saw, but there is a heavy wire were the bead seals. Ask me how I know...:bitch:
varosd
skrusins
I used the rubber from used paddle snow blowers. Your service centers trow them away.
tommyg
I have a piece of rubber flooring from the fitness center of the YMCA where I work. It's designed to endure heavy workout equipment and free weights dropping on it. Think I'm going to give that a try.
JERSEYHAWG /  Glenn
While we are on this subject, it can be done with the 2 stage also. I have seen pictures of it. I am considering that for next year, or maybe this year, job number 112 on job list ,,:lol:.  Any of you guys have a picture of that modification handy?
Glenn
Kurt-NEPA
Glenn
Glenn, I started out to do that on my two-stage.  I got the rubber and made some steel plate to hold it in place.  With a little care I was able to get the plate to housing clearance down to 1/16".  I called that good enough and never put the rubber in.
  • Similar Content
    • Evguy
      By Evguy
      I’m selling my B100 with 10hp Kohler engine and snowblower. The engine ran when I brought it home 3 years ago and deck ran smoothly. The 8sp gear box will need oil changed.
      I didn’t make headway and need the room for other projects.
      email or message me with questions
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
