lynnmor
PTO Issue
lynnmor
Now it's the PTO with a weird problem.  I just noticed that the outer end of the PTO was cut down to the snap ring.  With no groove left, it can possibly pop out at any time.  The only thing that I see can cause the problem is the spring retainer on the pin acting like a lathe tool and it cuts away the cast iron till the hard snap ring ends the cutting.  So when checking all three 520H's, the 1996 and 1997 were both cut down the same.  The 1991 was fine with no sign of any contact.
So now I need 2 good parts and whatever seals, bearings, snap rings and pins that are required to make it right.
Below are photos of the 3 PTO's.
ol550
Would get a couple new bearings and a little red Loctite and not look back. :think:
woodchuckfarmer
I second that idea .         Wayne
Ed Kennell
Third that...then put the spring retainer inside the PTO hoop so it doesn't rub.
Pollack Pete
I had the exact thing happen.Or at least a previous owner of one of my Horses had it happen.Luckily,I just walked over to my bone yard and got a new one off another horse.Amazing what metal against metal can do.That pin is made out of pretty good stuff.
MalMac
Sometimes this is the result of the PTO engagement rod being adjusted too tight. If that snap ring on the outside of PTO is the least be worn or the grove for the ring is worn, the shaft will be moved inward when the ring comes out of the groove thus causing the loop to be drawn inward against the PTO bell.
lynnmor
Thanks for the feedback, I am hoping to learn if this is a widespread problem and find a cure.  My snap rings were still in the grooves but the outer one was a bit distorted,  The end of the spring on the pin has wear on it and is worn to a shape like a drill point, that is the only contact that I can find.  I do run a lot of clutch pressure when using a two stage blower or 60" deck, but the 1991 runs both and there is no issue at all on that one.
The 103478-03 clutch is in its third revision which makes a total of four different parts, does anybody know what has been changed?  Again, my old one with no revision has no problem.
Putting the spring inside the hoop, as suggested above, should stop the cutting but the spring could rub against the hub.
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
