Miker-1
Tecumseh HH120
Miker-1
Just got a 1974? C-120 with a apparent Tecumseh replacement engine 12 hp. Wiring harness was changed, but works. I' am pretty sure it was a Kohler. My problem is it turns over through 3 compression strokes and stops starter. continuously. Bought new starter same problem. IT did start and run great, good idle and rpm range. Shut off and will not start same turn over problem. I placed my hand over carb and turns over as it should with no stopping .Lots of fuel on hand as expected. Any ideas! Do I need to include more information?  Model 10495 9  ser.# 46429  Thanks
Edited by Miker-1
More Infomation, no replies
pfrederi
What happens if you pull the spark plug does it crank freely??? Do you feel compression in the plug hole.
Lee in RI
Sounds like an ignition issue to me. Make sure it is firing on every compression stroke and not intermittently firing. Almost sounds like it is trying to fire just as the piston starts to come up from BDC. Is this point or electronic ignition?
Miker-1
Not sure about ignition, would this help HH88120-12018od Ser.# 4042
gwest_ca
You likely have the original engine to that tractor
Garry
Miker-1
yes it does and I grounded plug to check premature firing. same problem occurs. Ordered replacement starter. It acts like starter does not have enough torque. Do not want to burn up new starter. When it started it sounded great. Lost?
Lee in RI
 If it is a 12HP Tecumseh with solid state ignition, those coils/modules can do some very strange things. It could be advancing the timing to the point where it is causing the ailment you describe. I have had it happen on an old Sears suburban.
Lee in RI
Oops, I did not see that last post about you cranking it with the plug in and wire grounded. Try this before you condemn the starter: remove the valve cover and stick a .010 feeler gauge between the exhaust valve and tappet, crank the engine like this. If it spins over fine check to make sure your compression release is working properly.
Miker-1
How do I check compression relief, I have been thinking about ?
Miker-1
What was your solution
Miker-1
yes
Molon_Labe
Sure sounds like it is compression locking. Have you pulled the head and checked for carbon buildup? Excess carbon can increase compression due to the reduction in the amount of combustion chamber area. More carbon = less "squish" area for the fuel/air mix.
Miker-1
I will check this out, I have a new head gasket
pfrederi
That will also allow you to check your ACR (automatic compression realease0  The exhaust valve should open slightly during the compression stoke as you turn the engine over.
Miker-1
 The 010 feeler trick worked, what does this mean. What's next. Thanks
Lee in RI
Sorry I have been away so long. It sounds like your tappet is a little worn on the valve end causing insufficient valve clearance. Pull the exhaust valve out and file a little bit off at a time until you have the correct valve clearance. You should be all set once it is corrected.
Miker-1
If I'am filing valve wouldn't that give me less clearance. putting in feeler gauge increase's lift right. It makes  the ACR open more to reduce compression? Pulled head not much carbon.
Lee in RI
If I'am filing valve wouldn't that give me less clearance. putting in feeler gauge increase's lift right. It makes  the ACR open more to reduce compression? Pulled head not much carbon. Omg, I have not had much sleep in the past 3 days! Lol! I'm sorry, yes you need tighter clearance! You will have to replace the exhaust valve or the tappet. I would try a new valve first as that way you don't have to disassemble the engine. New valves are slightly longer to allow filing.
pfrederi
Is your acr working??  with the head off crank the engine over.  the exhaust valve should popup for a moment on eh compression stroke.
Miker-1
ACR lifts enough to get fingernails under, but spins great with 010 under tappet. Manual mentions  ACR pin but do not know where to look. Valve is .20 clearance TDC per spec. FYI picked up C-120 today Kohler 12 hp with a small electrical problem,  hoping it is a safety switch. But will not give up on Tecumseh HH120.I read Horses are like chocolate you want more!
pfrederi
tbarnhart
.020 clearance is a bit high for the exhaust valve and is likely part of the problem. The other possible issue is the pin on the camshaft mechanism that actually contacts the valve tappet and releases the compression. These will get worn over the years and will require either replacement or possibly a welding repair. The only problem is that you have to break the engine down to get to the cam. Try getting the valve specs back closer to correct and see if that doesn't work. Several different ways to accomplish this, although none are free. If the valve sealing surface is still thick enough, a machine shop can lightly grind the valve and seat which will close the stem clearance. A new valve may be necessary. A less recommended patch would be to have a good welder build up the valve stem with a hard filler and then grind it back to the proper clearance. Good luck. Those old Tecumseh engines are worth saving. When they are right, they have a lot of bite for their size and run very efficient.
Miker-1
If .020 is a bit high what would you recommend. I thought .020 was spec. How much lift should you have for ACR ?
tbarnhart
You're right, .020 is correct specs for the exhaust. The compression release will not open the valve very far. Probably only a few thousandths. Most likely the operating pin on the cam is worn. If the lift is less than the valve clearance, it won't open and the compression stalls the starter. That's why putting a feeler gauge in the gap makes it work again. You could try lowering the clearance to .015 and see how that works, but its not simply an adjustment. You're looking at one of the methods I described above. I have a 16hp ohv Tecumseh that has some of the same issues at times. Mine calls for .010 ex valve clearance, but I keep it a tiny bit closer to help the compression release work properly.
Miker-1
Thanks, Mike
  • Similar Content
    • KC9KAS
      By KC9KAS
      Need assistance! 1977 Wheel Horse C-120 hydro. I sold it to a young fellow last fall. His dad said he put a new battery in it but it still failed to turn over to start. I checked the only safety switch (with an ohm meter) and it is working correctly. I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad. I installed an old one that I had and it turned over and started right up. I already had the voltage regulator wires disconnected and read 36 VAC from the stator. When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die. The voltage regulator is grounded directly to the negative post on the battery. Once the wires were removed from the voltage regulator it would fire right back up! I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it. Anyone have any suggestions?
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • WHX??
      By WHX??
      Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are  such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable  Despite some hastily made plans of bribery,  chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
      I'll let Dan fill you in on the details if he has the stomach.  I would like to believe that that our beloved  ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
      Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857.  Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin  for
    • 608KEB
      By 608KEB
      One seat spring is about 1/4" lower than the other one. Has anyone had this problem. If so, what'd you do to fix it?
    • Tuneup
      By Tuneup
      Homer is a typical Southern man. When a tool breaks, he moves it to his backyard to be repaired another time. Turns out I'm the repair guy and have been attempting to barter for an old C-120 and a Commando 7 buried in the yard. He surprised me with the C-125 black hood a while ago after numerous mower, chain saw, weed wacker and whatever repairs. The horses are all out of a shop in Joplin now gone after the big blow... Soooo, 1 repaired old Sears LT and another that I took apart just so he could see after running without oil that the cam was in 4 pieces and the rod in 5 and he said I could have the 120. We pulled it out of the dirt with 4 flats, destroying several ant mounds in the process. Truly, not bad condition thanks to Homer's attention to the use of tarps. He tells me the 301 was bored .030 over and his mind is sharp for a 92 year old so I'm inclined to believe him. May be able to save that Commando in the near future if I repair that old Bolens GT14 first - and so on. So, my collection is now at a lowly 2. I don't think I'll restore this - will just make her a reliable runner and make the wife happy The deck can use a little metal but seems salvageable. Another C saved!
