oliver2-44
Putting Tubes in Plugged Tires
oliver2-44
I picked up a pair of 23 by 10.5 x 12 Carslie tires for free. They have 2-3 plugs in each tire, with about a 3/4" to 1" of plug sticking inside the tire.
I'm thinking of putting tubes in when i mount them, but wounder will the plugs poke a hole in the tube over time..
Before you install the tubes, what do you do ?
   Leave the plugs sticking inside & just install the tubes as is?
   Remove the plugs completely and install the tubes?
   Trim the plugs but leave a small amount of it sticking inside the tire?
   Trim the plugs smooth, flush with the inside of the tire?
Thanks in advance for the guidance.
cleat
I would trim them smooth.
The tubes are what will hold the air after that point, not the plugs.
  • Like 5
Racinbob
:text-yeahthat: I've put tubes in plugged tires with no issues. :)
ACman
Trim plugs smooth and put tire patch over plugs  :twocents-02cents: . This will keep the plug from pushing back in and give you a smooth surface on the inside of your tire. Nowadays they use what's called a plug/patch. Any good tire shop should be able to handle this quickly and shouldn't cost you a arm and leg either :) . Especially with the tires off the rim .
  • Like 6
953 nut
While in high school I worked part time in a gas station and lots of cars were using tube type tires. I put a tube in a tubeless tire that had been plugged (though I didn't know it) and that plug chewed a hole in the tube within a week. Granted, you won't be putting a lot of miles on the tire, but why take the chance.
  • Like 3
ACman
:text-yeahthat: , many of years and tires . Both ag type and auto . Not to say other ways won't work , just speaking from personal experiences . I would never use a plug (quick fix) , I could have the tire off , inside buffed ,cleaned ,glued (witch usually took the longest to flash) patch applied and tire back mounted in less than twenty minutes. This was done all by hand and a real old manual tire machine :tools-hammerdrill:. Sometimes it took longer to find the leak than it did to fix . I just wouldn't chance it and have to go through the whole process again.
TDF5G
:text-yeahthat:   Or remove the plug completely and patch.  Patches will hold for the lifetime of the tire if applied properly.
  • Like 4
Tankman
Done the same here. Tubes will be fine.  :text-yeahthat:
  • Similar Content
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
