Stormin
Land Roller.
elcamino/wheelhorse
That is very nice , better than the rollers that are filled with water. You did an excellent job.
Sarge
Make room on that weight box for a cheap small engine like off a push mower . Add a heavy shaft and a doubled pair of pillow block bearings with a belt drive to the engine . Mount about 3lbs of offset weight onto the shaft . Start engine and only engage belt while moving , otherwise it will try to bury itself in soft ground ...
I built one similar to that , but with a larger diameter roller and added an old 3hp Briggs engine , pulley drive with cable actuated idler pulley and a heavy shaft on double bearings . It would literally flatten the ground in one pass but if you went too slow it would start creating mud quickly and try to sink . Worked great , used it once and some guy riding past one day offered a hefty price so he owns it now - no idea where it even went . All the metal and engine was freebie garbage scrap , bearings were scavenged off another scrap job - worked fine for me . Plenty of ideas on YouTube out there....search out building a vibrating roller..
Sarge
DennisThornton
I'm thinking that is mighty fine!
And Sarge, I think you just took that up a couple notches!  Have you priced ride on vibratory rollers?
Thanks to you both!
chris sutton
Brilliant job Norm and well handy. :greetings-clappingyellow:
Stormin
You've seen it in action Chris. Used in conjunction with the grader blade.
Sarge! Converting to a vibrating roller is a future consideration if a small engine turns up.
KC9KAS
@Stormin Very nice yard roller.
By the way...is your lift table an old hospital bed?
Sarge
Biggest issue with the vibratory is isolating it from the engine itself - unless you like replacing engines . The further away from the engine , the better . Best design is an offset weight inside the roller itself but that's not easily done and requires super heavy bearings to withstand the stresses .
I ran vibratory cable plows for a few years - those things will loosen every bolt on the machine if you don't use crimped head locking nuts on every single fastener - even lock washers don't work . Ditch Witch knew what they were doing - their vibratory box is one of the toughest in the industry and they seem to last forever with the exception of main shaft oil seals which are easily changed . I actually used one with a 4' blade and knife cut right through 2 curbs and 10" of asphalt on a hot day like butter - the street was getting rebuilt anyway , lol .
Wish I had a picture of a friend's Dad's roller machine - it was built somewhere around 1953 by a local welder and he made 3 of them . It uses a simple old 9hp Briggs horizontal shaft engine that I overhauled the carb (had to make all the parts) , a simple power steering pump from car (Saginaw) and uses the hydraulic pressure to both drive the machine off of 2 hydro motors with a 3rd to run the vibrator in the rear drum . Weighs in around 2.5 tons and does a great job , although it doesn't turn very well .
I know from working construction that if you take a very large asphalt roller and put it in grass it's worthless , seen far too many operators get them stuck easily turning around in the median strip on Interstate highways . We used a big 20 ton machine once to knock down the bumps and holes in an equipment yard - that thing killed all the grass but the ground was extremely smooth.
Sarge
Stormin
Thank you and yes, hospital bed. On of the best things I've ever got for free.:handgestures-thumbupright:
chris sutton
How many engines do you want Norm. :lol:
ztnoo
Now THAT is a lawn roller!!!
WOW!
Very nice.
Stormin
Has Alan not told you yet? :D
chris sutton
Ot oh, told me what ?
Sarge
The more I think about it and as rough as this property has gotten I need to build another one - maybe put a pink paint job on it so no one will want to buy it out from under my occasional use . Wish I could find those pictures , they should have copied over with the other files off the old computer...aarrgghhh .
I really want to do one with a center cam weight like the big highways are built - it's a lot more effective and just takes mounting the roller's bearings in heavy rubber pads to protect them . Actually , the European made JCB uses a whole different setup and I'm told they last forever - might want to look at one closely....
Sarge
