jeff w 4 #1 Posted December 9, 2016 Looking to find (mounts) for skid shoes on my blade 79350. There is like a key hole area for mounting on the blade. Any info would be appreciated. Really like this blade on my C-81 w/chains. Manual down pressure is very functional as well. Thank you in advance Share this post Link to post Share on other sites
Ed Kennell 39,741 #2 Posted December 9, 2016 Do you have a picture. I have never seen a "skid shoe" on a blade. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #4 Posted December 9, 2016 (edited) The newer blades have them, and I made a set that would set a bit higher,Jeff. Looks like Jeff w those were put on by someone other than factory. Edited December 9, 2016 by WVHillbilly520H Share this post Link to post Share on other sites
jeff w 4 #5 Posted December 9, 2016 WV HillyBilly, thanks for the reply. I already have the two shoes (original), just not the mounts. However, I do like what you have there. Will get back to you if can't find original. Share this post Link to post Share on other sites
Ed Kennell 39,741 #6 Posted December 9, 2016 Thanks @WVHillbilly520H, I have seen the holes in the blade channel, but never seen ther shoes. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,177 #7 Posted December 9, 2016 Maybe these? Garry Adding https://www.partstree.com/parts/toro/accessories/92-6840-toro-skid-kit/quick-attach-assembly/ 1 Share this post Link to post Share on other sites
jeff w 4 #8 Posted December 9, 2016 Thanks Garry, downloaded the file, but, saw no photos. Currently have shoes, but no mounts. The mounts in pic I sent would be the ones if I find them. Share this post Link to post Share on other sites
benji756 341 #9 Posted December 10, 2016 Not sure if you can zoom in but heres a picture of my c-81 with the blade mounted, the skids on mine are round and they adjust up or down using a coupla nuts on the treaded rods. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #10 Posted December 10, 2016 Ok learn something new everyday I have an older blade but no provisions for skid shoes so I fabbed up a set using the wear edge bolts then I got the 260 and xi plows with the flat skid shoes,Jeff. Share this post Link to post Share on other sites
jeff w 4 #11 Posted December 10, 2016 Benji757, thanks for reply. I have the shoes like your, but, no brackets. Where did you find your brackets? Share this post Link to post Share on other sites
benji756 341 #12 Posted December 10, 2016 They were on the plow when I bought it I will try to get a better picture of it and post here for you but looking at your pictures it looks like you have the mounts already it would be the tubes with the bolt in them I think. Share this post Link to post Share on other sites
MalMac 1,332 #13 Posted December 10, 2016 There are no brackets, just the slots where carriage bolts slip through. Older blades do not have slots. Maybe the key hole your referring to is actually the bolt slots. Share this post Link to post Share on other sites
jeff w 4 #14 Posted December 10, 2016 Benji756, The photo I posted was just one I had found to show what I was looking for. Still looking & thanks MalMac, thanks for the reply...when I get to the blade I will photo the slots on blade and send for a look. Share this post Link to post Share on other sites
jeff w 4 #15 Posted December 10, 2016 MalMac---> photo of brkt mount? Share this post Link to post Share on other sites
benji756 341 #16 Posted December 10, 2016 Heres pictures of my blade, it looks like a po used 3/4 or 1" x 2" pipe nipples and welded them on. -No Subject-.zip Share this post Link to post Share on other sites
MalMac 1,332 #17 Posted December 11, 2016 Yep, that's it. Carriage bolt heads slip in through there, then skid shoes just bolt on. Share this post Link to post Share on other sites
