Notfishin 64 #1 Posted December 6, 2016 i been looking at these tires Carlisle At 101 size 24x12x12 and was wondering if anybody has used these yet. or what your thoughts are using these for a a stock wheel Horse Puller Tractor Share this post Link to post Share on other sites
Notfishin 64 #3 Posted December 7, 2016 I was hoping someone had a thought on this ! my thoughts the tread lug is not too deep and would act like a cut tire and not dig a hole and keep crawling forward I was hoping someone had a thought on this ! my thoughts the tread lug is not too deep and would act like a cut tire and not dig a hole and keep crawling forward Share this post Link to post Share on other sites
Zeek 2,286 #4 Posted December 7, 2016 I'm not sure about those . . . looks like they lacking some tread depth on the outside. I use Carlisle Super Lugs on my Cub puller, but you have find them used mostly now. Share this post Link to post Share on other sites
Notfishin 64 #5 Posted December 8, 2016 i would like to see a set of these , but no tire store stocks them where im at , have to order a set . not going to do that till i look at them first . i know the zero turn guys use them. figured someone had tryed a set by now Share this post Link to post Share on other sites
fast88pu 3,325 #6 Posted December 9, 2016 I ordered a set for my father's C-85 puller he's building. The lugs are shallow and ends rounded. But the lug is still and not a 45 degree lug either so they should work good for the lighter classes. Still have a few months till they start to try them out. Weren't bad on price at only $80.00 each compared to the $185.00 each I just spent on my firestone flotation 23 s that I just go go my puller Share this post Link to post Share on other sites
RandyLittrell 3,894 #7 Posted December 9, 2016 A guy I used to pull with used these and they work very well. I believe they made him pull with the guys running 26's. Randy Share this post Link to post Share on other sites
Notfishin 64 #8 Posted December 14, 2016 we can use up to 26 inch in stock class . but have to change drawbar height . we can use cut tires , but cant use professional cut tires . anything above 23 inch tires . has to change drawbar . cant decide if i want to cut some 24x12x12 turf tires and try that or buy these AT 101,s , im wanting to stay with the 24 inch or i would just use a set of cut Ag tires Share this post Link to post Share on other sites
Notfishin 64 #10 Posted December 23, 2016 i have allready got two center plates from miller tire and installed them in some 8 1/2 wheels and im going to order two sets of the 10 1/2 inch . wheels and some centers to install , we tryed using the uncut Ag tires . and they just dig down too far and fast . best luck we had are with half wore out ag tires and cutting them . You did a good job on those wheels ! and those tires look great ! Share this post Link to post Share on other sites
fast88pu 3,325 #11 Posted December 23, 2016 Thank you. I hope they pull well this up coming season Share this post Link to post Share on other sites
Notfishin 64 #12 Posted December 23, 2016 My biggest. Problem was getting the center in the correct place before I tacked it in place . Did you make a jig or just measure and wild .like it did .mine turned out fine .but I was worried. Share this post Link to post Share on other sites
fast88pu 3,325 #13 Posted December 24, 2016 My centers fit snug so I put a straight edge across and measured while tapping them into place Share this post Link to post Share on other sites
Notfishin 64 #14 Posted December 25, 2016 I'm hoping Santa gives me a gift certificate from miller tire.lol Share this post Link to post Share on other sites
