Notfishin 64 #1 Posted December 5, 2016 Guys i see the motors Painted on you Tractors , are you using same paint on motor and tractor , or is there a heat Engine paint that matches the Paint your using Share this post Link to post Share on other sites
Achto 28,013 #2 Posted December 5, 2016 2 hours ago, notfishing said: Guys i see the motors Painted on you Tractors , are you using same paint on motor and tractor , or is there a heat Engine paint that matches the Paint your using I used the same acrylic enamel on my tractor and engine. 2 medium coats on the block & 3 coats on the tins for the engine. The only place that the paint turned color on me was near the exhaust port, after I worked the engine hard. I think that even engine paint would eventually turn color in that area though. 1 Share this post Link to post Share on other sites
Notfishin 64 #3 Posted December 5, 2016 Thanks i just didnt want to spend two hours cleaning it. and then painting it , and run for a hour and the paint not hold . im putting header paint on exhaust . and Black engine Paint on the tins . but i could not find any engine paint same color as what i was Painting the tractor . for the motor !m using international Red from A tractor supply store . same as im paint tractor Share this post Link to post Share on other sites
oliver2-44 9,962 #4 Posted December 5, 2016 Ford red engine enamel is close to Rustoleum Regal Red color 2 Share this post Link to post Share on other sites
hermitman 116 #5 Posted December 5, 2016 I use Rustoleum High Temp. paint on all exhaust parts. 1 quart has lasted 2 years and I paint the woodstove with it. Never have had any problems with it other than it splatters alot! Dont brush it on near anything already pretty!!! Share this post Link to post Share on other sites
Texas Todd 1,025 #6 Posted December 6, 2016 I see that some paint the cylinder fins, but I prefer to not insulate them and let em breathe. But for the block and tins I have used Rustoleum Regal Red with no problem. Share this post Link to post Share on other sites
Notfishin 64 #7 Posted December 17, 2016 Well I got it done .used same paint as I used on the fram .hope she holds up. Thanks guys for the advice 4 Share this post Link to post Share on other sites
19richie66 17,537 #8 Posted December 19, 2016 Very nice looking. 1 Share this post Link to post Share on other sites
