mikeeyre74
What's this piece to?
Ed Kennell
mikeeyre74
I don't recognize that attachment at all? Doesn't look like a classic wheel horse thing to me that I have ever seen.. is it for a different series?
WVHillbilly520H
That my friends is part of the lift linkage for the 260 series snow plow ,Jeff
oldredrider
Jeff, you need to go on Jeopardy!
mikeeyre74
Amazing! Thanks!
DennisThornton
Mike.  You got the rest of it?  Including the hitches?  At least the rear?  I don't fully understand the rest that is needed...
WVHillbilly520H
I'd freeze up I'm front of lights cameras and audience :wacko:...
From what I was told when I acquired the blade ,that piece went on the mower lift linkage then the rod ran along/under the frame to front brackets that went into the front attach-a-matic and that is what actually raises and lowers the blade, because of the vertical shaft engine/belt drive it doesn't use the center lift link such as the classics and xi series then the rear hitch I have is actually a 2 piece part 1(the larger flat part with 10" hole) is bolted the bottom of the frame just for the blade then bolt on the second for the tiller and trailer/pin hitch, also I have all of the linkage and brackets left over from converting that plow to fit a classic,Jeff
Edited by WVHillbilly520H
mikeeyre74
Dennis, I don't have this thing at all. I'm trying to figure it out for an acquaintance of mine is all. He's trying to hook that blade to a Work horse series and wondering why it won't make sense.. hahaa! Now we know!
WVHillbilly520H
Mike if you need some help or ideas on the conversion PM me it was really straightforward and easy just study/ look at my pics and it helps if you have a classic style around for measuring,Jeff.
mikeeyre74
So you're saying the dimensions of the bald frame are fine.. and if he welds the tab there into the crossmember of the A frame, and gets himself an old style rear hitch, you can kinda knock the other stuff off the frame and hook it up?
WVHillbilly520H
100%...with the "tab" it has to be a little offset to the left or right about an inch from center can't remember right this moment and I/we used the 260 angle handle that will be on the "outside" of the foot rest instead of in board like the classics, and I made the axle hitch myself copied from my original,Jeff.
DennisThornton
I'm interested in a blade for my 264H.  Found one not too far but without the hitches and I'm not paying much for one without ALL the hardware!
WVHillbilly520H
Dennis I could "hook" you up,Jeff.
DennisThornton
I'm thinking you could if I was near Staunton VA.  Right now as winter approaches I wish I was!
Seems you are partly responsible for me having a 264H in the first place!  Thank you!  I truly believe they are deserving of more respect than they seem to get....
WVHillbilly520H
There's a Fastenal 5 mins from the house...
