Hacksawhero123
I love this ugly beast
Wishin4a416
Home made chisel plow. Looks good and it works great too.
Pullstart
Who gets to ride on the platform?
AMC RULES
Remember it's Thanksgiving...   :handgestures-thumbsup:
be sure to thank those neighbors for more :wh: seat time.
JAinVA
Lets see a box store lawnmower do that forty some years out.Mark,that looks great.Nice fab.JAinVA
dandan111
Wow that works pretty good.
608KEB
I grain farm and I think it looks more like a deep ripper! That will break up a compaction  problem !  Looks like you got your shanks in line with your rear tires too. Does the WH pull it  with  no problems?
Edited by 608KEB
JERSEYHAWG /  Glenn
Bad to the bone looking, what a job it does.
Glenn
Hacksawhero123
The grating platform was to strap concrete blocks on for more weight. It didn't really get down and dig, until I put the sweeps or chisel points on it. With the points on it really pulls down and rips close to a foot down. Remember, I have no previous experience with this and I'm making this up as I go. As far as the 'Horse pull it, the power and torque is there. A little more than half throttle gets it done. More aggressive tires loaded with weights weights would help, but we are getting along fine with what we have. I just want to say thanks to all of you that make this site the great place that it is. Where else could I find collectively thousands of years of experience and knowledge of machines that are pretty rare where I am (coastal Texas)??   I hope I can contribute to that wealth of knowledge. Thanks Fellas.
Mark.
Sarge
Just a warning -
Hydro transmissions are intended to operate at full throttle , especially when being worked hard . It's the only way it can produce full pressure and torque and still cool itself - otherwise you can overheat it quickly and burn up the pump . Make certain the cooling fan or fan-equipped pulley is in good shape and keep those fins on the pump as clean as possible , including cleaning up any oil/grease buildup . Operating temperature is best around 170*-190* , much over 220* it risks destroying the pump pistons .
I know it feels a bit odd running at high throttle and moving slow when doing work but it's a must to prevent hydro damage .
Sarge
Hacksawhero123
Thanks Sarge. I appreciate any pointers as I am unfamiliar with hydrostatic setups. It would be a good idea to print and read the operators manual for this machine before I inadvertently blow something up. I appreciate any input from you guys.
Mark.
elliot ness
Looks very good sir. And looks like it works well also.:text-bravo:
Hacksawhero123
Somewhere around my shop is a dipstick with a built in temp guage from one of my old Harley chopper projects. Might think of modifying it to fit the trans.
Mark.
Sarge
You could tap in a temperature sender by looking at the hydro diagram and finding a live port where oil flows through or use a spot in the case where the oil reserve level is located , but those gauges and sending units aren't cheap . Those dipsticks for a Harley isn't a bad idea if there is one long enough .
Sarge
TDF5G
On 11/25/2016 at 6:39 PM, Hacksawhero123 said:
Problem is the neighbors are asking me to bust plots for them.
Looks like an opportunity to make a few extra $.
r356c
Noted Sarge, thanks for the tip. My hydro old Yeller will be at full throttle from now on while dragging logs.
That is a nice looking implement there Hacksawhero123 !
  • Similar Content
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • ebinmaine
      By ebinmaine
      I don't have pictures yet but I can get some later. I know that will be helpful but I forgot to take them last night.
      So here's what I know.
      When I bought my c-160 last year it came with a plow. It was delivered to my house and the plow was not mounted on it. I never saw this particular plow on that particular tractor.
      The plow I have is 42 inches wide and has a full frame as most of them do.
      The angle lever has the Z shape to it, NOT a straight stick of metal, and also bends slightly back towards the operator.
      When I am pulling the angle lever towards me to change the angle of the plow it contacts the brake lever.
      Any thoughts?
    • ebinmaine
      By ebinmaine
      I have at least 7 hubs on different tractors that I would like to add a second set screw to.
      I have an older but good quality floor model drill press.
      I have the tap set.
      I don't recall ever using the tap set to do anything other than clean out threads. Not make my own thread set.
      Can anybody give any particular advice?
    • ebinmaine
