Bowdoinham Dan
Mounting Instructions
Bowdoinham Dan
Does anyone know where I can find mounting instructions for my dozer blade?  It's on an A-frame mount, model 6-4113 7.  I have a Raider 10 tractor.
Racinbob
Here ya go:
Bowdoinham Dan
Thanks--I've seen this file.  It describes how to put the blade on the frame, but I'm looking for instructions for mounting it onto the tractor.  Does such a manual exist?
Racinbob
I see what you're saying. Use this one. Different number but that doesn't matter.
gwest_ca
Here is the other half of the 6-4113 plow package
Garry
AMC RULES
jeff lary
Dan is that Bowdoinham Maine by any chance? I have an Uncle that lives down there.
  • Similar Content
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
    • ToroMan
      By ToroMan
      Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542.  I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly.  Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need!  I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know.  One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
      Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
      From Toro site:
      Model #: 79355
      48" Snow/Dozer Blade
      Model #: 95-4090
      48" Dozer Blade Retrofit Kit
      Thanks!!!
    • Trouty56
      By Trouty56
      Tractor vs. Implement cross reference chart for models from 1955 - 2000
      110 pages 513.43KB
      This chart lists the original attachment model
      The model that replaced the original model
      The model that was available when the list was made
      Often many models between the last two are not listed.
      You must go from year to year and follow the model numbers to see them all.
      For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
      OR
      Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
      STD for a model indicates that attachment was standard equipment that came on that model of tractor.
      Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
      1970 *VS           rear discharge mower deck                             5-7362 is correct replaced by 5-0610 both CCW rotation
      1971                  rear discharge mower deck                             5-0600 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
      1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
      1973 *VS           rear discharge mower deck should be model 5-0611 - CCW spindle rotation
      1970 *VS          side discharge mower deck                             5-2365 is correct replaced by 5-0700 both CCW rotation
      1971                  side discharge mower deck                            5-0710 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
      1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
      1973 *VS           side discharge mower deck should be model 5-0702 - CCW spindle rotation
      1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
      *Models using a vertical engine crankshaft
