![Rhondalea](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Model 104107 - fixing and selling - need advice
By
Rhondalea, in Wheel Horse Tractors
Similar Content
By jebeli
Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
I could possibly deliver or meet half-way or ship.
Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
42in high-shoot snow blower
42 in rear discharge deck
Snow blade
Front mount deck hanger with 42in side discharge deck
30in lawn seeder
Brinly single bottom plow with cleavis or sleeve hitch
50in grader blade
Extra transmission
36in rear tiller - leaks a little
Full set of tire chains for each tractor
Various body pieces
7.5 cubic ft pull behind cart - may need tires
Extra set of rims
All required belts, pullys, brackets, manuals, too much to list.
By LengerichKA88
We have a Charger 10 that I’ve had on here and gotten help with, but I’d never really looked at the ID Tag.
Today while looking around it I took note of the model number, so as to help with narrowing down parts in the future. The model number listed on the tag is 1-7931.
After a google search, “1-7931” returns as a Charger 9. Would this be a case of using left over tags, or possibly an error? The tractor has an HH100, and is badged as a Charger 10, but from the Charger 9 manual I found, I couldn’t find an engine model number listed, just “9hp”.
Picture of the tag is included.
By LengerichKA88
I liked, but didn’t find an applicable thread, so I made a new post.
We got a 69 Charger 10 last Friday. The brakes don’t really stop it, kinda slows it to an idle speed. Still too fast for the brakes to be engaged. FIL did some reading and it’s apparently the gears that stop the tractor, so now we’re looking at servicing and possible actually doing work on the trans. That’s fine, not a problem, figured we’d get into this eventually, so with the one known issue at hand, how would/have you gone about tackling this trans?
Trying to get voices of experience that might be able to save us a headache or two lol. TIA!
By Builderchris
I need some help. I just purchased 3 garden tractors, plus implements, from a guy on Craigslist and I'm having difficulty identifying one of them. It looks to me like it's a C100, but honestly for all I know it could be a Raider10 or a charger10 just as easily. I'm really not sure. The tag under the dashboard reads, Model T10, Serial # 329650. When I googled Wheel Horse T10 I got nothing. Can one of you great Wheel Horse guru's help me out?
Thanks
Chris
By Deadguy
So, today two more horses followed me home. These critters sure are friendly! Somebody should have warned me that they breed like rabbits! Anyways, the first is a B80 with the 8 speed and a 16hp Kohler. The metal is straight and it runs strong. It does need a governor adjustment and the voltage rectifier needs to be hooked up. The tires look ok, but they are very hard and are starting to crack. The second is a Charger 10 with hydro trans, an 8hp Kohler that smokes a little, and duallies. This tractor needs a new voltage rectifier, one new rear tire, and an engine rebuild or new engine. These tractors came as a package deal with a bunch of parts, including a couple mule drives, a 30-some inch universal snow plow, and a 38" triple blade rear discharge deck. $400 took it all home. How do you think I did?
