pgiro
D-160 - Looking for new Cutting Edge for 56" blade
pgiro
Hello,
Trying to locate a new cutting edge for a 56" blade for a D-160.
If I'm looking at the right document, it should be: 103618 PLATE-BLADE EDGE
Tried looking up the part number but maybe it has been superseded.
Can someone point me in the right direction?
Thank you.
KC9KAS
Most of us just get a piece of steel 4" wide X 1/4" thick X (what ever length you need).
Drill holes 1/2 way up (2" from the edge) and you can flip it in a few years and use the other side.
Do a search on here for lots of ideas for a new edge including rubber, UHMW and other items.
Sarge
Here is what I used - 1/2" x 60" pre-beveled 1055 steel
http://www.discountsteel.com/items/1055_Steel_Beveled_Cutting_Edge.cfm
Another Ebay source and a bit thinner -
http://www.ebay.com/itm/3-8-x3-x66-Hardened-Cutting-Edge-1055-Carbon-Bucket-skid-steer-loader-tractor-/122004042520?hash=item1c6801f318:g:xOYAAOSwgQ9VhXPj
My 56" blade was severely worn and damaged from the previous owner , so I had to weld it . 3/32" 7018 first pass , 1/8" 7014 final pass to fill/cap . Full length weld both front/rear . The damage was bad enough that the new edge couldn't be bolted like the original , hence welding it on . Just have to watch travel direction and moving around as well as heat input or you'll warp it badly .
There are a couple other Ebay sources -
60" 1055 steel , pre-beveled just like I used -
http://www.ebay.com/itm/Titan-60-Bucket-Cutting-Edge-Hardened-1055-Carbon-Steel-1-2-Tractor-Loader-/361569665662?hash=item542f3b427e:g:71sAAOSwyDxXhlfs
42" for the smaller blades/plows - again , 1055 steel
http://www.ebay.com/itm/3-8-x3-x42-Hardened-Cutting-Edge-1055-Carbon-Bucket-skid-steer-loader-tractor-/122133776666?hash=item1c6fbd891a:g:xOYAAOSwgQ9VhXPj
Just a note -
1055 isn't too bad to drill and file for carriage bolts . Use a good quality cobalt bit and slow rpm with a decent cutting fluid like TD Foamy (Fastenal) . 4-corner files can be found but aren't exactly mainstream - I have 5 different sizes and cut patterns now . Or, spend the money on several sizes of square hole broaches and use an arbor or hydraulic press . I wouldn't recommend having a shop use an ironworker as those bits are not designed for hardened steels and irritating the local welder is a bad idea...not to mention parts for those machines are holy crap expensive . Local guy got a bill for $275 for 4 holes ...lol .
Sarge
pgiro
Thanks for all the comments. I will probably buy a piece of flat stock, but just concerned about getting the square cutouts for the carriage bolts.
82Caddy
You don't have to use carriage bolts...could easily (I've done it) just drill a hole and use a regular hex head bolt with nylock nut.
Sarge
Four corner square file -
https://www.kmstools.com/blog/wp-content/uploads/2014/12/KMS_File-ID-Chart.pdf
Pferd square files - http://www.pferdusa.com/products/201a/201a02/201a0211P.html
Grobet square file - https://www.knifeandgun.com/ProductDetails.asp?ProductCode=32.415
USA made Johnson square , I have one and like it very much - http://www.ebay.com/itm/Vintage-10-Square-Bastard-File-10-File-Johnson-Brother-File-Co-Made-in-U-S-A-/391616716776?hash=item5b2e2cdfe8
Simonds square larger holes - one of my absolute favorites and cuts quickly - http://www.ebay.com/itm/SIMONDS-73-436000-14-SQUARE-BASTARD-FILE-NEW-MADE-IN-USA-/380784897931?hash=item58a88c6f8b
With either the Simonds or Johnson files I can make a round hole square in less than 2 minutes once the layout work is done . Just use a scribe and a square to lay out the holes after drilling the base diameter for the bolt section .
Sarge
pgiro
Sarge,  Thanks for the tips on the square files. I will probably pick one up.
Sarge
I need to buy 2 more to complete my "set" .
In looking back , might have been cheaper to buy the set of square press broaches but they can break easily....ugh.
Sarge
pgiro
Just to follow up on this topic, I ended up finding the exact replacement cutting edge from http://www.jackssmallengines.com/.
It was about $55 shipped, which was about the same price as the flat bar stock that I found online, due to the high shipping cost, and for which I'd have cut the holes and use a square file to make the carriage bolts fit. Much better option to buy the exact replacement cutting edge. It even came painted.
Sarge
How thick was the replacement cutting edge ? I'm curious as well to see if it's actually hardened steel or just standard X60 or 1018...
Mine is actually cutting down the top surface of the asphalt drive..
Sarge
pgiro
I believe it's 1/4". Probably just standard steel.
Sarge
The 1055HC I linked to is actually cutting down the asphalt - need to make some skids for this blade today as we're getting a storm right now . So far , no marks in the steel edge despite ripping out several pieces of concrete with it on the last storm .
Sarge
