Wburger86
Need Help Iding 42in Snow Plow
Wburger86
Hi. I need help iding this snow plow please! I was given it and i cant figure out what the model is due to crappy id tag and what itll all fit.The blade is 42 inches. Thanks in Advance for any help!
KC9KAS
:WRS:
SPINJIM
The model number showed up better in the photo than it probably did in person.   It's model number 6-7123.
If you go into 'MANUALS' on this forum, and then "IMPLEMENTS', then do a search for 6-7123, you will see the info you need, including which models it fits.
Welcome to Red Square :D .
Walt
:WRS:
AMC RULES
:text-yeahthat:  :text-+1:
:WRS:
squonk
I believe that plow fits the vertical shaft engine'd tractors
Walt
The model number shows up as 1975 model using the WH interchange pdf it shows tractors A 80 (R) and A 80 (E) as models it was for in that year.
