1968 Raider 10 Restoration
By
WheelHorseNut, in Restorations, Modifications, & Customizations
Similar Content
By ebinmaine
A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
The generosity of some of our members never ceases to amaze me.
This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
It's rough. Very much in need of a full disassembly and restoration.
When it came here it was missing one tie rod and the other was broken off one end.
Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
The engine wouldn't move.
Tin was near chock full of skeletal mouseseses and their house.
Cleaned that out and the engine spins freely now.
So progress has been made.
It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
By Ralpho711
I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different. Any help is greatly appreciated. I'm brand new to the site and think its great!
By Red144runner
I mow 7 lawns on the side 3 are neighbors. One in is a good size and flat. The only pita is a swingset. I like using the tractor on it for several reasons, it does a beautiful job, it needs to be bagged and with I only need to empty twice, my proline 36” I empty 7-8 and it’s a good excuse to run it for 90 minutes.
By Goldnboy
For those who have repaired 8 speed transmissions what items are the source of failure? Forks? Cluster gear? Bearing?
Water is obviously enemy #1
Along with no oil as #2
By tntatro
Hello, this is my first transmission rebuild. It was off a 1972 Raider 12 so I thought it had a limited slip differential and took it apart to see why both wheels were not grabbing. It turns out that it has the 8 pinion differential. There is a damaged bearing, I destroyed the plug for the detent passage and some of the gears have wear but it doesn't look bad to me.
My questions are:
1 - If the other bearings are complete with no damage do I leave them or is there a way to test the amount of wear to indicate whether they should be replaced or not?
2 - Where do I get a new 1533 bearing, plug for detent hole, oil seals and gasket and how do I remove the bearing?
3 - The gear pictured was the gear with the most wear. Is that perfectly fine to use?
4 - I'm guessing that it is a 5091 transmission or a 5073 with the differential replaced. Is there a way to tell what it is for ordering proper parts or are parts going to be the same?
Thanks, Tim
