By
WVHillbilly520H
A while back I posted I made some of these skid shoes, Now that I have moved on/up at work and don't have direct access to the machines I used to make these I'll pass along how and what I used, if anybody has the tools/skills to do so or has a favorite fab shop...first up the to scale blue print then some pics of the final product, also I made mine with more adjustments than the factory Toro ones, I used 1/4" wall 3"x8" rectangle tubing cut to size and then drilled 4 holes and mill cut the slotted holes, next I bent a weld filler rod to the angle of the original shoes (short black in pics) approximately 15° angle as a guide as I set the "L" shaped parts long side in the vise jaws then using the "blue wrench" Oxy/Acet torch heated along the bend till dull cherry red using a large adjustable wrench to slowly work the foot to the angle of my guide wire may have to repeat this step multiple times till desired results then quench in water, bead blasted and ready for paint powdercoating...Jeff.
