Gunman64
310-8 size tires?
Gunman64
What's the biggest tire that I can use in the rear of a 310-8? Would 23X10.50X12 work? Thanks
953 nut
:WRS:          That is what I have on the rear of my 312-8 (virtually the same tractor).
Gunman64
How do they fit, are they real close to the fender?
Sparky
If you mount the 10.5 tire on the standard width rim (7" or 7.5") it will be a bit taller than 10.5....might be close to the fender. The WH factory only mounted 10.5 rubber on the wider rims (8.5"), those rims came on the 520's and the GT-1800's (I think there was another model but I cant remember).
  Mike..........
wallfish
418-C had those too.
Or, at least mine does
Edited by wallfish
Duramax7man7
  Mike..........
23" is the height, 10.5" the width and 12" the rim...
I was considering some 24" which would be about 1/2" from the seat pan.
953 nut
Mine came already mounted on the 8.5" rims so there is no ballooning due to narrow rims; I should have mentioned this.
Gunman64
I've  found a guy wwth some 23x9.5-12 for a good price. Should those work with stock rims?
Sparky
Those are a better choice for your stock rims than the 10.5's.
 Mike....
857 horse
these are 24x12.00x12...........on 12 wide rims......i know....wrong tractor......but i cant follow directions...
12 inches of rubber,,,,flat on the ground..
Howard857 Horse in Va
Gunman64
Holy Moly, those look sweet!
WheelHorseNut
@857 horse That looks awesome!  It's like a pro street car from the rear!  Love it!
doc724
Just be aware that not all tires with the same specs are actually the same size.  Kenda tires run wide. Deestone tires are smaller in diameter than the specs.  Dico's and Titans are what WH used as OEM tires.  Carlisles are probably the best but they come at a price.  If you are going to buy new rubber, buy 4 ply-more resistant to thorns.
Duramax7man7
I just slapped some 23 x 10.5 x 12 @ 6ply lugs on my newly painted rims and WOW, that was a B! Needless to say I put the tires on from the back to save the front of the rim.
 Had to sand and paint a bit of the edge of the rim afterward though. ha ha. Looks good now. though.
 Also keep in mind that bigger or smaller overall diameter of the tire will either increase or decrease your speed by a little. Bigger tires will increase and vs versa.
