edgro
Steering Column Upper Bearing Repair
JC 1965
WOW  !!   Very nice clean fix.   :thumbs2:  Thanks for sharing.
DougC
Looks like a snow thrower shaft bearing and a couple if sandwich flanges. make a couple spacers and voila!!!!   Nicely done.   :handgestures-thumbupright:
cleat
Nothing better than ball bearings on the steering shaft.
Will last forever and make steering so much smoother and easier.
DennisThornton
Well I'm liking that!  OH!  I forgot to "like" that...
edgro
Thanks for the comments. the steering is good and tight now. here are pics of my "steering wheel removal"
Fun Engineer
Edgro
Where did you buy this?
WHX??
1 hour ago, Fun Engineer said:
Edgro
Yes inquiring minds want to know! I was thinking about some type of pillow block bearing??
@cleat didn't you do something like this to your 520's?
Edited by WHX8
cleat
I got rid of the bushings, drilled the hole bigger, and pressed in wheel bearings.
Here are pics of both early and late style 520's that have ben converted.
Cleat
DennisThornton
Cleat
I was rapidly scrolling down and saw some pictures and said to myself, "That looks like something Cleat would have done.".  Scrolled back up and YEP!  He did!
benji756
I used a 2 bolt dodge pillow block bearing on my 520 I'll get some pictures as soon as I can and for my steering wheel removal I cut the shaft and made a clamp using 2 3/4 inch 2 bolt clamps and a piece of steel tubing I'll get some pictures of that also.
I was amazed at the difference it made on how easy it steers now.
edgro
I bought most parts on ebay and also some from TSC.
I did see that TSC has the bearing and retainers, which I had gotten off ebay
Sarge
You can also sleeve the steering shaft a bit or weld it up if necessary and use bronze sleeve bearings - they work great .
Sarge
USHorse
Edgro,  does that bearing swivel to compensate for the shaft running down at an angle?  Or is that just an illusion?
Edited by USHorse
Missing word
edgro
Yes. The bearing holder is slightly concave, and the bearing is slightly convex. this allows the bearing to be mounted at an angle from the bearing holder
USHorse
Thanks Edgro.  I've got a 416 that has the sloppy steering wheel because of the fatigued metal it passes through. Steering wheel impossible to get off (by my efforts).  So, going to cut shaft right below wheel.  Using other RS member's ideas, purchase a 3/4" quick connect and new wheel that mounts to the quick connect.  Will have to drill hold through the shaft for the quick connect. But, I think I will try your shaft support idea as hardware is off the shelf.  I am not a metal fabricator or welder so limited in what i can do.   If a big hammer constitutes a metal fabricator, than i am one :D .
Great images from all those posted here.  Will attempt fix during holiday break if garage is not too cold.
ohiofarmer
It only takes a second to add a few drops of oil to these bushings [if you think about doing it]  Another bushing that can wear big time is the idler pulley for the transmission belt. You find these on the newer toro series stuff and on plenty of bushings on the MTD type stuff. I got a MTD for free and the thing steered HARD. Bushings and even the front spindles were dry. Almost too late for the oil, but it will still run with some slop in the steering :(
Edited by ohiofarmer
