Solex 27 #1 Posted October 29, 2016 Recently picked up a 1994 Kohler Command 12.5 HP engine, CH12.5S. The starter is different then what I am used to, incorporates a solinoid mounted on top of the unit. It looks like it requires power from two sources to make the starter function. What is the procedure to wire this starter? Where does the addition power come from. My experience is limited to older Magnums where power is limited to one connection off the remote solinoid then to the battery. In in addition do you know where I could find a wiring diagram for 1994 Wheelhorse? I believe the company used this engine on some of the later 300 series tractors? Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted October 29, 2016 Can you add a picture of the starter? Share this post Link to post Share on other sites
Solex 27 #3 Posted October 29, 2016 See pictures, notice the additional electrical post for the second power connection Share this post Link to post Share on other sites
Walt 339 #4 Posted October 29, 2016 Looks like your starter has the solenoid mounted on starter like a GM starter Battery would go to large post and wire from ignition would go on a small post. Picture of end of solenoid with posts showing would be better view of were wires attach. Share this post Link to post Share on other sites
N3PUY 1,031 #5 Posted October 29, 2016 Top terminal straight to battery (+). Spade terminal to ignition switch (S). Bottom terminal is already connected into the starter. 1 Share this post Link to post Share on other sites
Solex 27 #6 Posted October 29, 2016 Thanks for the help, didn't even think of going straight off the battery. So what happens now with the other solidnoid attached to the tractor? Will I still need to run power to it, or does the starter mounted solinoid eliminate the need for it? Share this post Link to post Share on other sites
pfrederi 18,333 #7 Posted October 29, 2016 If all there was were the two heavy wires and one light one from the switch, take it off Share this post Link to post Share on other sites
