FatJackDurham
1972 GT14 Carb cleaning and build
mikehusky455
I bought a new carb and new fuel pump from ebay for my k321 pd.about $70 for both not bad.
FatJackDurham
Alright. Carb cleaned up nicely with a dip in the GUNK dip tank. Choke plate tapped back into shape, drilled out the brass nubs and cleaned up the threads with a 4-40 tap. Best of all, I had two tiny ball bearings from an old Marbles tang aperature sight. So the detente is back in place and everything looks good. However, I won't get the gasket kit until tomorrow. Also, the engine needs a serious degreasing. I think all of the gaskets must be shot. I am hoping that after I clean all the linkage parts with the governor and get a new throttle cable that it will all work more smoothly. But that will be two weeks, because I have to go to SF next weekend.
mikehusky455
ive had my 69' gt14 for almost a yr so far and still haven't tryied to start yet since I got,seems low compression just by spinning by hand but will see soon.good luck.
MWR
On 10/26/2016 at 3:54 PM, WHX8 said:
It will take paint off Jack, yes Walbro is a brand of carbs you might see out there, I personally never had serious issues with them ...except for on weed wackers.:wacko:
Thanks for those links Dick...:handgestures-thumbupright: might come in handy in the shop!
You'll have to send Fat Jack a link to your videos now MWR!
FatJackDurham
Keep them doggies rolling!
FatJackDurham
Carb cleaned and the engine back together. Unfortunately, I broke the governor ROD connector and have to get a new one. But the engine started and idled well.
i also need a new shut off valve.
i concerned about the electronics. The pto doesn't disengage, the lights don't work and there is at least on broken connection out of the rectifier. And I need a new ignition switch. I think I am going to have to retire it all. I am worried some connectors will break that can't be repaired.
ztnoo
If the PTO is a Warner electric clutch, it has to: (1) have voltage to it,  and (2) be solidly grounded, or it won't function.
Also low voltage from a failing rectifier spade or wire which is supplying insufficient voltage to charge the battery, can lead to an inoperable PTO clutch.
Ask me how I know.
I had no idea why my Warner unit wouldn't work suddenly until I found a mostly burned off rectifier spade.
New rectifier, new connectors, problem solved.
Test the clutch directly off a fully charge battery with a jumper wire. Make sure the body is well grounded. If the clutch "clicks" and moves, it works.
Make sure a newly installed rectifier is well grounded also, or it won't do its job of charging the battery.
Edited by ztnoo
  • Similar Content
    • aaronthomas57
      By aaronthomas57
      Hello Everyone,
      The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
      I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
      Thanks for taking a look.
    • tractorboy79
      By tractorboy79
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • tomabrown77
      By tomabrown77
      my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
      I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
      ps i was on forum about 5 years ago,  forgot my username so i joined again
