FatJackDurham
GT-14 no brakes?
FatJackDurham
Hello, I just got a 1972 GT-14 is pretty good shape, a little sluggish, but the transmission seems to work well forwards and back.
But, when I push the brake pedal, suddenly I am in free fall. It pops the transmission lever into neutral and the tractor rolls freely until I take my foot off the pedal and grab the lever and put it in reverse.
Is this the normal behavior? I know the seventies were weird, and a garden tractor with a cigar lighter is pretty tight, but stopping is kind of a thing with me, so I'd appreciate some insight.
I am the third owner of this beastie, and it came with all the original brochures and manuals. The owner's guide only says the brake and parking brake work in connection with the automatic transmission. So, I am wondering if I am missing a connection or linkage, or worse, that there is something broken. I traded a Winchester 92 for this tractor and am as excited to finally own a Wheelhorse as I was to finally own a winchester... so anyway, there it is. Thoughts?
953 nut
:WRS:    The brakes on the GT-14 consist of dynamic braking of the transmission and a parking brake which is probably chewed up by now. The attached Sundstrand manual has an adjustment procedure in it. As for the sluggish operation, the first thing to do is change out the fluid ( ATF if it is red, 10W30 if amber) and replace the filter with a NAPA 1410. This may be all that is needed.
Sunstrand Hydro (part 1).pdfFetching info...
Sunstrand Hydro (part 2).pdfFetching info...
Sunstrand Hydro (part 3).pdfFetching info...
Sunstrand Hydro (part 4).pdfFetching info...
Let us know how you come out.
Walt
:WRS:
FatJackDurham
Thank you! The sluggish isn't the tranny, it's the engine. Needs carbs cleaned. I'll examine you attachments!
SylvanLakeWH
:text-welcomeconfetti:
KC9KAS
:WRS:
meadowfield
If it's set up properly then it will lock the wheels when you hit the brakes, it will then roll slowly as the fluid escapes.
dont ever pull the handbrake rolling, it will chew whatever is left of the transmission brake pawl
FatJackDurham
I found this post, now, that shows the pawl. So, I gather for the parking brake, the pawl drops into a gear tooth to hold the wheels steady, correct? And they get destroyed over time by people dropping it into the gears/internal milling head while the vehicle is still moving.
But, that doesn't help me understand how the brake works. I have seen some animations that suggest in hydrostatic trannies, that by just putting the gear in neutral, instead of forward and reverse, the hydraulic action itself is the brake. But I don't know if the same applies here.
ANyway, I'll take a gander at the parking brake setup and see if I can adjust that in till it bites.
pfrederi
You are correct it is the hydro unit itself that provides the "braking" .  Problem is as the hydro wears (allowing leak by) braking becomes less powerful.  Later hydros Wheel horse added a physical band brake.
Edited by pfrederi
FatJackDurham
Okay, so two questions pop into my head now:
1) Does the wear you mention that can decrease brake efficiency affect the normal operation of the automatic drive, or is the braking feature a different "path" inside the hydro gear unit, that can degrade separately from the transmission? I am asking because the transmission is "spritely" to say the least, and when climbing hills, the engine bogs down, but the transmission doesn't seem to slip at all. So, as a beginner, my instinct is that the drive part of the hydro is working.
2) Does the brake pedal have any connection to the transmission other than disengaging the drive lever? Or, is simply moving the drive lever back to neutral EXACTLY the same as hitting the brake pedal?
Thanks.
pfrederi
Actually it is pretty much the same hydro system. The engine can makeup for some of the age related weakness.
Can you push the tractor at all engine off and the tow valve in drive position?
Yes all the brake pedal does is push the control lever to neutral. There are some adjustments you need to check to assure it is moving it to exactly neutral.  I do not have GT14 so I defer to other members and the Owners manual on how to check the adjustment
FatJackDurham
Okay, great! I will check the pushing with the tow valve, but unless the tow valve is already in the tow position and I didn't know it, I'd say yes, because I pushed it off the trailer with it off. I'll let you know! Thanks for the answers.
pfrederi
If you can push her with the tow valve in the drive position the she is probably a bit tired.
953 nut
Make your adjustment to the brake system and then you can give the transaxle the old acid test; chain it to a tree and put it in forward and see if it spins the wheels. then chain the front to the tree and hit it in reverse, same deal. If it is not strong it may need the acceleration springs replaced. Mine was puny and member @refracman hooked me up with a fellow who has some a few years back; big improvement.
FatJackDurham
Thanks for all the hints.
1) I can push it easily with the tow valve in the drive position...
2) I don't now about a tree, but when I was using the plow to push dirt, the engine booted down before the wheels spun, but I had wheel weights, and I weigh 350 so I don't know if that counts.
does a bit tired mean I got a bit taken? I tried to find out if the tranny was good when I bought it, but I didn't know enough....
what do you suppose my options are?
953 nut
Have you done the carb cleaning yet? I have had good results with Seafoam products, remove the air cleaner and with the engine running at half throttle, spray the aerosol carburetor cleaner in until it begins to die out, once it recovers repeat several times. Also, add Seafoam liquid to the fuel. Hope this helps.
pfrederi
Being able to push it (more than a foot or two) with the valve in drive is not a good thing.  If you are lucky the valve itself may not be seating correctly.  Download the sundstrand manual form here and try removing cleaning and reseating the tow (also called push) valve.
http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/
Has the fluid and filter been changed recently??
FatJackDurham
Not sure. My plan is to take the tin off this weekend, degrease the sucker and wheel it into my workshop for an extended stay.  You'll be hearing more from me in the months to come....
Sarge
Those are typical signs of weak direction valve springs in the older style hydrogear - that is common. There are places that have parts available, look up LJ Fluid Power in Michigan - they have a lot in stock. The GT14's had a lot of issues with neglect and abuse due to their size and power - mostly abuse. If you find any model from that era that still has a stout hydrogear - they are amazing when the work correctly.
Sarge
  • Similar Content
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • MS GENERAL REPAIR
      By MS GENERAL REPAIR
      Good Morning Ladies & Gents;
      I operate a Small Engine & Power Equipment Repair Shop From my home in Bridgeport, Ct.
      Yesterday I started repairs on a 1984 +- Wheel Horse C-145 Automatic Lawn & Garden Tractor.
      I decided this would be a good candidate for a repair video series on my new Youtube channel. Since the repairs on this tractor are not the usual carb cleaning & belt replacements.
      Someone suggested that the Wheel Horse enthusiasts on this site might find this information useful and I hope that's the case.
      Problems I'm aware of and being addressed include........... Motion Works Linkages, Hydraulic Implement Controls, Brakes & Parking Brake, Mower Blade Mounting, and whatever else I find as repairs progress.
      Repair Video's have been a tremendous help to me on all types of things that I don't have a service manual for, and if this helps someone then the effort will be well worth it.
      As I post this there are 4 video's in the series. More will be added in the coming days.
      If you find the video's helpful please like, comment & subscribe, so I can mold the channel into a useful resource. It takes a lot of extra time to video document repairs, so it's good to know if it's worth it.
      This Tractor belongs to a repair client and is Not For Sale
      Good Luck With Your Repair Projects..........................Mike
    • 69-Raider-10
      By 69-Raider-10
      Just brought her home an hour ago! Ran it through the paces and everything checks out! Now shes coming in the shop to get a good tune up, the Bolens plow taken off and replaced, fluids change, some rewiring, a motor cleaning and a couple of new gaskets, and a good carb cleaning. And maybe some fuel lines. 😁 This is my first hydro so its taking some getting used too. LOVE the hydraulic lift though! Dont know how I lasted this long without one!
    • mkueb
      By mkueb
      I have an issue with my mid 1970's D160 garden tractor.   Plowing snow over the weekend it begain to make an awful grinding sound come from what appears to be behind the motor.  Once this happened,  all the hydraulic stop working and the forward reverse lever seem to be stuck in the middle position.   I shut down the tractor and was able to release the value on the pump and tow the tractor back into the garage.   When towing it back to the garage,   I noticed the rear wheel where moving ok (with the release valve open)  In the garage,  the forward / reverse lever will move back and forth.   I did attempt to restart the tractor again without any luck.  The sound seemed to be the same.
      I am speculating that I have a pump issue on the hydrostatic drive.   It' not the spline coupler with I know can spin out.   I did have this happen about 10years ago and at that time,  I removed the pump and had shop replace the shaft.   This time,  the shaft is definetly spinning the pump making a sound that I can only describe as a high pitch grind combine with what sounds like gravel rolling around inside of the a barrell.
      Does anybody out there have any advise?    Is there any checks that I can do to make sure it is the pump?  I friend has suggest lifting up the rear end and seeing if the wheels spin in opposite directions by hand (with our without valve closed?)   Is it possible that I may have damage something in the rear end?    I did notice after replacing the spline on the pump 10 years ago,  the tractor would still roll backwards with the value closed and the tractor not running.   I was not concerned at the time the tractor seem to move fine forward and reverse.
      I do use the tractor for many task.  I have the rotor tiller,  snowblower,  deck,  category 0 connection with back blade.   It's a nice little tractor and I would like to keep it running.   It has the Onan 16hp engine which I have only had to rebuild the carb back about 10years ago due to some lugging issues.   For the most part,  engine is good burns a little oil (I change it every month in the summertime), and runs best on 90 REC gas.
      If anybody has any recommendation for how to troubleshoot the most recent problem,  veryify it's the pump,  rule out any other possilbe rear-end damage, and possible recommend next steps,  I would be greatly appreciative.    Thanks  Marc   (FYI,  I live in Western Michigan between Grand Rapids and Kalamazoo).
