Texas Todd
Here Goes the C-160
Wishin4a416
Didn't take you long to make up your mind. Have fun. I did a 160 a couple of years ago. Keep us posted progress.
Thisguyisnew
Forget the PB and cave that sucker in with a punch. There are some good posts on this forum about removing the exhaust fitting with this method and the best part is that it not only works but it is also a lot of fun...
Texas Todd
That was good advice! It wasn't pretty but it worked. Had to use  sawzall to cut a slot and it cam on out with some force. Was able to get the nipple in Almost a half inch
Thanks for the tip!
The remains are on top of the head.
I have a companion thread over in the transmission forum regarding my adventure with it...
roadapples
Using this method, wouldn`t you get a lot of metal filings inside the engine?
oldredrider
A shop vac takes care of that issue. I recommend running a tap inside to chase the threads after removing the old pipe.
Texas Todd
Agree on the shop vac. If I had a 1" tap I would do just that. I'll just have to run this nipple in and out a few times and call it good. Maybe I will run across one though......
oldlineman
sometimes you can make severial cuts with a hacksaw in the nipple and it will act somewhat like a tap, use plenty of oil on it.
Texas Todd
Thanks! I will give that a try, but it is going in a half inch. Does it really need more? Seems pretty solid.
DennisThornton
Hacksaw cuts help but you can even grind a taper and cutting grooves just like a tap that will most likely be plenty good enough for a single use!
Texas Todd
Didn't get a great deal done today, but had a great conversation with @stevasaurus and got the transmission cleaned up and ready tp reassemble once the seals and gasket are delivered (Thursday, so they say).  The inside of the transmission is pretty clean after a scrub down of diesel with a wire brush and elbow grease.
Had a little time left so I cleaned up the block and got it painted.
Since I have the block painted, I will probably jump in and blast the cover and tins and get that portion finished and ready to reinstall before attacking the next item, which will probably be the frame, or hood, or fender.....Depends on which the way the wind blows.
Edited by HD-Horse
  • Like 9
stevasaurus
Excellent pictures Todd, and excellent talking with you yesterday.  :)
Texas Todd
Likewise sir! Glad you have my back!
Hacksawhero123
On metal filings in the exhaust port. It sounds goofy but....  take a can of foamy shaving cream and shoot a bit to the back of the threaded section. It will catch and hold the filings and crud. When finished, use a shop vac to suck the cream and crud out. A wise old aircraft mechanic showed me that one.
Mark
  • Like 9
Texas Todd
Just an update. Finally got all the pieces blasted, primed and painted. Now the real challenge sets in....Waiting for the paint to cure before starting to put it back together.
Also, any suggestions on seats is appreciated. The recipient of this tractor, my son-in-law, is about 6'4 and 240 lbs, so I need to find a seat with good suspension and one that can be mounted far enough back so he won't be too cramped.  I have a stack coming from @jimkemp so that decision is made.  I was going to add more white accents but the SIL wanted all red, except the wheels of course. It seems that the disassembly and reassembly are the fun parts. The blasting, grinding and priming is monotonous...Painting isn't bad because you know the reassembly is getting near, but then that impatience gene kicks in....
Tempted to start tearing down the 856, but wisdom says not to have two tractors torn apart at the same time.....
Oh...and...the pics. Rough count is about 200 individual pieces to blast, prime and paint, for the tractor alone......
  • Like 8
Texas Todd
Patience is over rated.
  • Like 6
Wishin4a416
Nice! Coming along real good.
Texas Todd
Coming along. Got some No-Mar tire lube to mount the tires. Good stuff. Makes a world of difference.
Picking up one of the Northern V-3500 mid back seat this week. Graphics ordered. Stack on the way.
Couldnt decide on red or black for the seat springs..Went with Red.
And my next project followed me home....
  • Like 6
Texas Todd
A little more progress today. Hope to wire it up and test fire20161114_171854.jpg Friday or Saturday.
  • Like 7
JERSEYHAWG /  Glenn
Todd, what color are you using please? And is that a rattle can Job? It's real purrty, and coming along great. You sure not asleep at the wheel.
Glenn
Texas Todd
Thanks Glenn. Its Rustoleum Regal Red, Acetone and Valspar hardener shot out of a Harbor Freight HVLP gun with a 1.4 tip. The hardener gives it that extra shine and it dries very hard. Primed with Rustoleum self-etching primer. Seems to be a good combination and also allows touch ups with rattle can Rusto.
I painted my mailbox with it a couple months ago to see how the paint would hold up over time.  I figure it has seen more sun than the horses will see in a year or more time and it still looks brand new.  If it still looks new this time next year, then I think the horses paint will hold up well.
TravelinJavelin
I love the white engine screen that just pops right out! ohhhhhhhh I love the 160's man!
Texas Todd
I agree! I had it painted red and it just laid there. After doing the one behind it, the choice was simple.
  • Similar Content
    • CHuls
      By CHuls
      *Estate Sale*
      71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
      Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
      Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
      Not sure what it's all worth together but, make an offer.
    • PMeadows
      By PMeadows
      Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
    • RJ Hamner
      By RJ Hamner
      The C-160 just wasn't running right. Started with new points, plug, filters.
      I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
      Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
      It purred along for about 4 minutes and just quit.
      First thought was "out of gas".  Looked in the tank and sure enough it was really low so I filled it up.
      Tried to start it again .....NOTHING
      Went and rechecked everything ....NOPE
      Got out the can of starting fluid...NOPE
      Pulled the plug and noticed the gap was ZERO.  Re-gapped and tried again.  Same thing again no gap.
      Pulled the head.  Looked normal.
      When I cycled the engine I noticed that the exhaust valve didn't fully retract.
      Was able to remove the exhaust valve with two fingers!!!!!
      Guess I am in the market for a new set of keepers and a few gaskets.
      The guys at McHenry's Small Engine Love Me
    • tractorman99
      By tractorman99
      Hi everyone,
      I bought a wheel-horse c-160 a while back, and did some work with it.
      One day the rear axle housing broke:
      I was thinking about changing the part or soldering the broken pieces.
      Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
      Thank you in advance!
    • RJ Hamner
      By RJ Hamner
      Picked up this C-160 a couple of weeks ago from Joe out in SW PA.  It had been on the Classified page for a while so I went out for a look.  Got her home and got a new battery, new plug, new plug wire and some fresh gas.  She purrs like a BIG kitten!  Drove her around the yard a few times and put her on the lift.  Got some of the parts I am going to need at the BS and some more from Jay in GA.  Wife told me I have to finish the all the trim work in her "home theatre" in the basement so......... I do get a few hours in.  After all, "Ya gotta let the finish dry between coats"
