Oberg111 5 #1 Posted October 22, 2016 I have a 1971 Wheel Horse charger 12 with a 12 horsepower motor in it wondering what the best oil to use is going into winter going to be plowing snow with it and if there is a good engine additive for the oil to put in with it Share this post Link to post Share on other sites
rmaynard 16,690 #3 Posted October 22, 2016 Contrary to what Paul suggested, I use nothing but straight 30W year round. 3 Share this post Link to post Share on other sites
Ed Kennell 43,757 #4 Posted October 22, 2016 Like Bob, I use 30W year round. But I do keep my winter horses ( plows and blowers) inside a heated garage. I am not sure if the 30W would cause starting problems at lower temps. 2 Share this post Link to post Share on other sites
Jerry77 1,218 #5 Posted October 22, 2016 5w-30 or 10w-30 --seems like a good choice - my pole barn isn't heated, so wouldn't want to use straight 30w.. 3 Share this post Link to post Share on other sites
Ed Kennell 43,757 #6 Posted October 22, 2016 (edited) The manual actually states: above 30F use 30W 0-30F use 10W30 below zero use 5W20 Edited October 23, 2016 by Ed Kennell 4 Share this post Link to post Share on other sites
Achto 30,166 #7 Posted October 22, 2016 5 hours ago, Oberg111 said: if there is a good engine additive for the oil to put in with i I add a little Lucas oil treatment to all my engine oil, about 10%. On the ones that tend to smoke a little I add a heavier mixture up to 50%. 2 Share this post Link to post Share on other sites
Oberg111 5 #8 Posted October 23, 2016 Do you use the synthetic Lucas or the conventional , I am a fan of both I use the synthetic in my diesel truck 1 Share this post Link to post Share on other sites
Achto 30,166 #9 Posted October 23, 2016 I use the conventional. I only use conventional oil in my older engines so I stick with the same on the Lucas. Only reason I don't use synthetics on my older engines is that I experienced a leaking issue after using it once. Don't know if it reacted badly with the seals or what. My newer engines get nothing but synthetic. 1 Share this post Link to post Share on other sites
slammer302 2,156 #10 Posted October 23, 2016 I'm on the fence about what oil to use for winter. Thinking about using 10w-30 full synthetic with alittle Lucas heavy duty oil stabilizer. I don't have a heated grarge. If I did would probably stick with 30wt. Share this post Link to post Share on other sites
Shynon 7,505 #11 Posted October 23, 2016 4 hours ago, Ed Kennell said: I use 30W year round. But I do keep my winter horses ( plows and blowers) inside a heated garage Share this post Link to post Share on other sites
pfrederi 19,241 #12 Posted October 23, 2016 12 hours ago, Ed Kennell said: The manual actually states: above 30F use 30W 0-30F use 10W30 below zero use 5W30 I read it as below 30 you can use either 5w-30 or 10w-30 when it goes below zero 5w-30 is prefrred 2 Share this post Link to post Share on other sites
Ed Kennell 43,757 #13 Posted October 23, 2016 This is from the OP manual. 1 Share this post Link to post Share on other sites
erwine13b 27 #14 Posted October 27, 2016 Anyone ever use the oil that they make for actual walk behind snowblowers? I use it in my snowblower, but am not sure if I I should put it into my WH for snowblowing as this is my first year using a snowblower. Anyone ever use the oil that they make for actual walk behind snowblowers? I use it in my snowblower, but am not sure if I I should put it into my WH for snowblowing as this is my first year using a snowblower. Anyone ever use the oil that they make for actual walk behind snowblowers? I use it in my snowblower, but am not sure if I I should put it into my WH for snowblowing as this is my first year using a snowblower. Share this post Link to post Share on other sites
