Similar Content
By Hardy6
Hi I recently got an old charger 12 that had been sitting in a friends backyard for at least 20 years. The engine spins over and the starter works but it has no spark, I’ve been looking online for some solutions but I can’t seem to find any other charger 12s with my ignition setup. It seems to have a sort CDI box but I’m not sure. Does anybody know how this works or any tips on how to test for where the problem is ?
By Slightly Discombobulated
I need some help. I picked up a 1968 electro 12 (1-7235) that I'm assuming is an early model built with a leftover 67 engine because the engine patina matches the tractor and it has an external generator/starter instead of the magneto. It's a k301S-4712B. I bought it knowing that the engine turns freely and that it had no spark. Being 52 years old I figured it deserved some fresh ignition parts so I replaced the coil, condenser, points (cleaned and set to .020), spark plug (.035), and plug wire, and I still cannot get a spark at the plug or through my spark plug tester. It turns over okay and I've got 12 volts to the positive terminal on the coil. It's been many years since last worked on this type of ignition system and I'm stumped. I would appreciate any input/suggestions you might have. If it were something newer I'd suspect a safety switch but I can't see that this has any.
By firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
By ebinmaine
As if we don't live far enough out in the sticks already.
We're going to go a few hours North and hang around rough camping with the moose for a few days.
Can't even begin to tell you how much I'm looking forward to it!!
By Team70R
Scored a 606 for free. Got it going tonight and there is no 3rd gear. If you force it and let off the clutch it just grinds. Any suggestions??
