Hacksawhero123
Greetings from Houston
Hacksawhero123
Greetings all.  I recently picked up a 1975 C-160 Auto. I managed to fire it up the other day. Probably the first time in at least ten years. It's such a neat old machine. My plans are to get it in serviceable shape, use it for a while, then blow it apart for a complete resto. I'm glad I found your site. Lots of great info here.
  • Like 6
KC9KAS
That is a fine machine!
:WRS:
AMC RULES
:WRS:
Sparky
:WRS:
 Interesting decals....not original but definitly cool, never seen them like yours before.
  Mike.....
Terry M
:text-welcomeconfetti:to :rs:
Glad you found us!!:)
Walt
:WRS:
benji756
:text-welcomeconfetti: to:rs: :banana-rock:
SylvanLakeWH
:ph34r:
Hacksawhero123
Thanks Fellas. I don't know about the decals. If not original, they have been there a long time. Paint looks original. I was amazed at how solid the deck is for having sat in the weeds for so long. I'm having difficulty posting in the parts wanted section. I'm needing a fuel tank and brackets. Mine is MIA but the tray is there.  Also needing headlight lens and a pair of front rims. I'd like to find a tiller somewhat close to home. Thanks again for the welcome.
Mark. 281-739-4886
Edited by Hacksawhero123
Added phone number
KC9KAS
As of 2 years ago, the headlight lens was still available from a TORO dealer....around $40
953 nut
:WRS:    We are glad you found us too. The 160 is a great machine and looks like it is need of a little love, glad you are going to bring it back to life. Having a hydraulic lift is a big plus too.
JC 1965
C160 is my favorite tractor. Thanks for sharing and     :WRS:
Achto
:WRS:
DougC
Hello and    :text-welcomeconfetti:.    Enjoy the forum!   :)
jay bee
I think you're going to like it here.  There is a vast amount of knowledge awaiting you, simply for the asking.  Thanks for sharing the photos and :text-welcomeconfetti: to :rs:
Jim
oliver2-44
Welcome!
There are a few Texas members on here. I'm up the road a ways in Marble Falls.
Good luck with your C-160!
  • Similar Content
    • CHuls
      By CHuls
      *Estate Sale*
      71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
      Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
      Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
      Not sure what it's all worth together but, make an offer.
    • PMeadows
      By PMeadows
      Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
    • RJ Hamner
      By RJ Hamner
      The C-160 just wasn't running right. Started with new points, plug, filters.
      I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
      Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
      It purred along for about 4 minutes and just quit.
      First thought was "out of gas".  Looked in the tank and sure enough it was really low so I filled it up.
      Tried to start it again .....NOTHING
      Went and rechecked everything ....NOPE
      Got out the can of starting fluid...NOPE
      Pulled the plug and noticed the gap was ZERO.  Re-gapped and tried again.  Same thing again no gap.
      Pulled the head.  Looked normal.
      When I cycled the engine I noticed that the exhaust valve didn't fully retract.
      Was able to remove the exhaust valve with two fingers!!!!!
      Guess I am in the market for a new set of keepers and a few gaskets.
      The guys at McHenry's Small Engine Love Me
    • tractorman99
      By tractorman99
      Hi everyone,
      I bought a wheel-horse c-160 a while back, and did some work with it.
      One day the rear axle housing broke:
      I was thinking about changing the part or soldering the broken pieces.
      Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
      Thank you in advance!
    • RJ Hamner
      By RJ Hamner
      Picked up this C-160 a couple of weeks ago from Joe out in SW PA.  It had been on the Classified page for a while so I went out for a look.  Got her home and got a new battery, new plug, new plug wire and some fresh gas.  She purrs like a BIG kitten!  Drove her around the yard a few times and put her on the lift.  Got some of the parts I am going to need at the BS and some more from Jay in GA.  Wife told me I have to finish the all the trim work in her "home theatre" in the basement so......... I do get a few hours in.  After all, "Ya gotta let the finish dry between coats"
