RedHorse54
Picked up another one!
AMC RULES
Nice :wh: score. :handgestures-thumbsup:
T-Mo
Nice pickup.  Love the cart, btw.
AlwaysLookin80
Looks great! I'll be there in a bit to pick it all up ! Lol
Wishin4a416
That is a very nice Tractor. Very nice shape.
RedHorse54
Thanks guys:)
JERSEYHAWG /  Glenn
You know, now I have to find one. Nice score.
Glenn
elliot ness
Fantastic score.:text-bravo:
Pollack Pete
VERY nice tractor.And........it will keep you know what warm in cold weather.Have fun with your new toy.
72Raider8
Very nice! Lucky dude! I want an RJ!
Gracie's Dad
Is that a jack stand on the tongue of the cart? I have never seen one of those. My tub cart certainly doesn't have one!
wallfish
Nice score for another RJ.! Has ALL the goodies (except a recoil). Don't see too many of those plow blades anymore either.
I kinda like that that stand for the cart.
Noticed the belt guard is spaced off the engine a little far. Not sure why, but if it has 2 separate pulleys (like it should), one goes on the outside of the guard to run attachments. The PO must've been a tall guy too since the seat is lifted and huge foot rests.
RedHorse54
Yeah, guy said it was original but I think someone welded it on there
i actually have a Fairbanks for it, I'm gonna try to get it on today so I can take some more pics. And yeah you're right about the belt guard, I'll have to check that out
RedHorse54
Cleaned up the RJ a little today. I took off the extra custom stuff, and the stickers that weren't suppose to be there, and installed a Fairbanks recoil. Next is draining the bad gas, cleaning out the tank, putting good gas in it, then try to get it to run
wallfish
Ah Ha, the belt guard is spaced off because the tension spring is on the wrong side. Spring should be connected on the other side between the lever and a small tab on the trans side plate. Small tab with a hole in it is bolted on with the side plate bolt below the axle tube.
ACman
Nice score on RJ and accessories :) ! It looks the cart was also beefed up on the rear where they usually bend .
Could you post post some good  :text-coolphotos: of the snowblade . I thought mine was a simplicity but now it looks as the previous
Person cut my tube to clear his costume simplicity weight setup  and put in a piece of flat iron. I'd really like some measurements on the tube and close ups of the rear of blade . Try to put back to original . Thanks
TIGman
Nice!!!  That would have to be on my "Wish List" for sure.
An RJ and or a Suburban.... what the heck, make it both. :handgestures-thumbupright: ;)
RedHorse54
Thanks wallfish, I'm gonna try to fix that soon. I see where it's suppose to be now. This rj has a walbro carb on it, can I use a k91 carb rebuild kit to rebuild it, or would that not work?
I'll try to get out there tomorrow to take pics:handgestures-thumbupright:
wallfish
9 times outta 10 I just clean all carbs and hardly ever use a rebuild kit.  Seems the only thing that ever needs to be replaced is just the bowl gasket. Doesn't make sense to me to change a float needle valve that isn't leaking. Definitely used more kits on Tecumseh carbs but now even that's a waste of time since you can get a whole new one for less than $20.
The big problem is when you get the 10th one that has had water sitting in it for a long time or 20 years of old gas. Or a fixed jet carb.
Pull it off, thoroughly clean it and put it back together. Change the bowl gasket if it looks too bad or leaks. Fire it up and make adjustments.
RedHorse54
Last night I drained the bad gas out of the tank and the bowl on the carb, cleaned the bowl real good, cleaned out the tank with good gas, put a new gas line and filter on it, and after a few pulls it fired up. The gas was sitting in it for 5 years. Now it runs great
Tonyp
Love it !
TDF5G
She sounds mighty fine!  The only thing I didn't like about your video is that it's TOO SHORT!!
RedHorse54
Took some pics last night.. Will be getting some goodies for it in the next few days. Can anyone guess what it is?
codeman83
very nice! im jealous hope to get my first rj soon
redrooster
Nice horse! I want a round hood some day!
  • Similar Content
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • Robert Concato
      By Robert Concato
      Hi I'm new to site. I am looking for a gas tank for an RJ 35 Tractor any help would be great thanks!
    • wh315-8
      By wh315-8
      Looking for the measurements for items #69 mounting bracket and #79 lifting rod. So that I could fabricate and be able to install on my RJ59. Any pics of the mounting bracket would be a big help.
    • Clay Dodson
      By Clay Dodson
      RAINES AUCTIONS **LIVE AUCTION SEPT 16TH @ 10:00 AM WITH PREVIEW FRIDAY 9:00-5:00 AND ON SATURDAY @ 8:00 AM UNTIL AUCTION TIME**   <CLICK HERE FOR PARTIAL CATALOG>      ^^PRE REGISTER NOW TO AVOID LONG LINES ON THE MORNING OF THE AUCTION.  CALL KATIE AT 540 775 3880, SHE WILL ISSUE YOU A BIDDERS NUMBER.  THEN JUST SHOW YOUR ID AND PICK UP YOUR BID CARD ON FRIDAY AFTERNOON OR SATURDAY MORNING^^           See below for 3 preview videos of the BIGGEST selection ever of Farm Tractors, Garden & Yard Tractors, Riding & Push Mowers, Implements, Bush Hogs, Finish Mowers, Chain Saws, Weed Eaters, Generators, Snow Blowers, Chippers, Tillers and tons MORE all SOLD ABSOLUTE RAIN OR SHINE!!!!    Including 80+ Wheel Horse Tractors, Wheel Horse Raider Models 10, 12, 211-4, 656, 416-8, C-160, Wheel Horse Charger Models 12, GT-14, A100, C160, D160, D200 w/blade, 310 B, 856, 317, 332, 854, 212-6, 211-5, 520-8, 211-3, C-120, Lawn Ranger,  Antique & Rare Tractors including David Bradley Suburbans, Panzer T707 & Chain Driven Bolens, John Deere Models 650, 110, 112 L, 70, 420, 214, 316, 317, 318, 160, 111, 116, 212, 216, 332, Massey Ferguson 135 Diesel, Economy Power Kings & Jim Dandy models 1614, 2414, 2418 & others, Ford, 2 Yanmar 1500 & 2000, Simplicity Models 725 w/blade, 9020, 6216, Baron 7014, 7114, 2210, 3414, 637, 3012, 3410, 728, 3415, 3314, 7116, 7117, 5116 Special, 6211, 9020, Early Speedex Chain Driven Tractor, Scarce Very Clean Pennsylvania Meteor Model 1010, Gravely, Allis Chalmers, Case, Turf Trac, Toro, Cub Cadet, Troy Bilt, Honda, Craftsman and many many others.    ***CLICK HERE FOR PREVIEW VIDEO #1***   ***PREVIEW VIDEO #2***   ****PREVIEW VIDEO #3***     ##LOAD OUT TERMS ARE AS FOLLOWS## THERE WILL BE AN INDEPENDENT PERSON LOADING OUT LARGE MOWERS & TRACTORS FOR $10 PER UNIT IF YOU NEED THAT SERVICE.  DUE TO THE LACK OF ROOM, THERE WILL BE *NO* LOADING USING LARGE EQUIPMENT UNTIL AFTER 2:00 PM. WE WILL SELL THE TRACTORS & EQUIPMENT IN THE FRONT AREA FIRST SO LOAD OUT CAN START ONCE WE ARE DONE WITH THAT AREA, ABOUT 2:00 PM.  YOU WILL ALSO BE ABLE TO LOAD OUT ALL DAY SUNDAY, MONDAY AND TUESDAY THE 19TH UNTIL 5:00 PM.  AT THAT POINT, ANY ITEMS LEFT BEHIND WILL BE SALVAGED UNLESS YOU HAVE PRIOR PERMISSION FROM THE AUCTIONEERS, RAY RAINES OR CLAY DODSON.   ^^SPECIAL RATES AT THE ZION CROSSROADS BEST WESTERN (WHICH IS ONLY 3 MILES FROM THE SALE) IF YOU MENTION RAINES AUCTIONS^^  CALL 540 832 1700 AND REMEMBER TO MENTION RAINES AUCTIONS TO SAVE$$$~     **CLICK HERE FOR HOTEL ACCOMMODATIONS SUGGESTIONS**    Mark your calendar now for this Colossal auction that is not to be missed~    Ray Raines Auctions VA License #3395
