bmsgaffer
Project 525EXI - 25HP Fuel Injection Repower
bmsgaffer
Big step today, started placing the engine!
Everything fit quite nicely except for the high pressure fuel pump, which cleared the top part of the frame rail, but hit the bottom curved portion. I have removed the pump bracket and will mount it on a plate off the top crossbar for the engine compartment. Luckily there is plenty of room behind the side covers on these engine compartments (I am assuming left room for water cooled kawi and diesel) and the pump should fit behind no problem. I will only have to shorten up some fuel lines.
It worked out for the better anyway as I realized that because of its sunken position, with the fuel pump in its original place I would have never been able to reach the engine mounting bolts.
I did also have to move the front part of the oil cooler up about 1/2" so that it would clear the top of the frame rail. I may have to do something with the feeder fuel line where it comes through the firewall, it is very close to the oil cooler and I don't want it to get too hot or kink right there.
That's as far as I could get tonight, but here's to hoping there is no other major hiccups! :handgestures-fingerscrossed:
shallowwatersailor
Brandon, did you think of relocating, I think, the voltage regulator low down on the left side attached to the shroud? I know for the CH to access it you need to loosen the engine mounting.
bmsgaffer
I did contemplate it, my concern was cooling. They stick that regulator right in the shroud with a decent heatsink. It looks terrible to replace stuck down below the frame rails.
I will have to see if there is a remote mounted version with a larger heatsink or at least a surface to mount a heatsink on, as it sees quite a bit of airflow where it is now.
My original thoughts were: well I have to pull the engine to clean the shrouds anyway every few hundred hours or so, I will just replace the regulator whenever I am in there. If it dies before then, then I will just clean the shrouds sooner... :lol:
That is the one thing that is really difficult with these xi's, they make them really serviceable (how easy the fenders and sides come off and even with the removable top crossbar in the engine bay!) but then they drop this engine all the way down in between the frame rails with no lower access points for anything! Oh well, still better design than most I have come across...
bmsgaffer
It's ALIVE! And sorry, I don't have video yet. I took it for a spin last night in the dark. That 25HP doesn't even flinch when tooling around at full speed, and smoooooth.
I was able to get everything hooked up and working. Had to notch the chassis where the high pressure fuel pump sits. I also was able to make a wiring adapter for the connection that allowed me to not have to modify the tractor or the engine wiring. The disadvantage of this is that because of the way the XI ignition switch works I had to replace it with an older style 103990 switch which means the headlights will be on all the time unless I put in an extra light switch. (I like the tractors setup this way better anyways, never liked the key-switch light control).
Also I may have to put in a small circuit for the oil pressure light/hour meter to make sure it works right with this engine.
I got the new tires mounted up and it looks mean!
On the to-do list:
  • Finish work on the PTO spacer, not planning on needing this till spring
  • Sort wiring minor things (headlight switch, oil pressure/check engine light)
  • Small normal issues (neutral setting on hydro, one on my new axle oil seals is still leaking)
  • Fix the lingering attachment lift issues from when I purchased it
  • Make the exhaust come out the hole on the right, fit shields
  • Polish, polish, polish.
Edited by bmsgaffer
  • Like 7
19richie66
Brandon, that looks fantastic(and factory installed too). great job.
fatboycowen
So awesome. I hope you'll consider posting a video of that beast running!
What's an engine like that go for? I can't say I'm not tempted.
bmsgaffer
Thank you! I cant take that much credit though, the engine is almost a drop in. I had to study lots of parts and drawings and buy some off the shelf parts with some minor adaptation. (Don't look at the hole I cut in the chassis, that does NOT look factory :lol:. )
Absolutely! I will get it together a bit more and take a good video of it. Lets just say that I got the tractor for such a good deal I felt I could pay a bit for the engine... ;)
Sarge
Wow , that engine looks like a great candidate for a D series .....hmm
Sarge
bmsgaffer
Sorry about the pops and cracks at the beginning of these, one microphone going out on my phone.
First Run:
Cold Start and Test Drive:
WARNING: Bad videography - The test drive may make you dizzy. The only good video is at the beginning, then the rest is just for the sound of the sweet ECH730 humming along :lol:
Edited by bmsgaffer
  • Like 6
WVHillbilly520H
Brandon good job well done, got a little dizzy on the second video with POV driving lol,Jeff.
bmsgaffer
Sorry about that! It wasn't even good POV as I had you pointing at the ground, looking up would have probably been better!
The only good view is at the beginning, the rest is mostly for the sound... I should add a warning.
Edited by bmsgaffer
bmsgaffer
I think the long cranking at the beginning (cold start) is due to my fuel line route causing it to have a hard time keeping fuel up at the mechanical lift pump. I believe It also waits for the oil pressure to build up a bit.
I may solve it with an electric pump back by the tank, but I am not certain yet. It seems to run great otherwise, so I may just deal with it.
shallowwatersailor
Brandon, does the EFI engine use a choke? I noticed that the handle was full-on.
I'm impressed and having a conversion like this will add to the longevity of the 5xi  series. You will like your choice in tires.
bmsgaffer
John, there is no choke on the EFI engine, its just disconnected and one of the boys must have left it all the way up.
Does the DXI have a different dash panel or is there just no choke lever in it? I may have to try to track one down somewhere to clean things up a bit.
I already like those tires. I can walk straight up a wet-grass hill without any sign of slip. I am hoping with enough weight that I can run without chains this winter. We shall see on that though, I have a somewhat steep driveway.
shallowwatersailor
I know what you mean about "cleaning" things up. The Dxi only has the throttle slot on the dash so would work. I'm not sure how expensive it would be plus the hassle of putting it on though.
I had the Kenda's on at the end of the snow season and I do a neighbor's driveway that is fairly steep. I used the 518xi with the snowblade and just four suitcase weights on back. It did it without a problem.
bmsgaffer
Well I will keep my eye out for one, as I have lots of things I will want to adjust (add a 'check engine" light) and I want to modify all the warning lights to LED's so I can take my time and then do a dash swap later when its time for a new steering wheel boot.
I also have to figure out why the oil temp dash sensor doesn't work. I got a good used sensor but something still not working on the dash.
Lots of little not-important things I will work out of just in time to have to drop a new transmission in in another 1000 hours or so :lol:
JERSEYHAWG /  Glenn
Coming along very nice.
Glenn
bmsgaffer
I have had a bit of a jump in progress. One of my biggest hangups was the exhaust. The EFI muffler needed a little tail welded to it to get the exhaust out the hole in the side panel so I could put the hood back on.
58d894795edfc_2017-01-1223_04_13.thumb.jpg.a30ef8db9ec0e41f15a67ddf89c73951.jpg58d894841b3d7_2017-01-1223_04_23.thumb.jpg.5ea3dfb9d718dfc83a4f6358ffcaf25f.jpg
Finally got all that welded on and painted and exhaust wrapped. I used a different ignition switch as the one that came on it was flaky. This one doesnt have a position for lights, so they stay on all the time. I will add a separate switch for them later as that is how I like it better anyway. I also installed a digital hour meter/ tach for quick reference for service intervals monitoring.
2017-03-21_18_06_32.thumb.jpg.f2a18e72041d70968f1405817f0ed3fc.jpg2017-03-21_18_06_42.thumb.jpg.8008441793689f4e0ee0e61fdd1303f9.jpg58d894b01e2e4_2017-03-2118_06_57.thumb.jpg.e68223a55db23162efb371e1b7a9c271.jpg58d894bd8f356_2017-03-2118_07_25.thumb.jpg.3163e615ae209dc6840807bfe9f63ba8.jpg
Still left on my to do:
  • Make a new PTO spacer that is keyed and has flat sides to put a wrench on when working on pto.
  • Headlight switch
  • Check engine light wiring is a bit different than the oil pressure switch was.
  • Like 3
  • Excellent 1
19richie66
Looks great!
Super-C 4 me
Very nice project
  • Similar Content
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • gfullz
      By gfullz
      Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
      so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
    • GEnd
      By GEnd
      Hi all,
      New to the group and hoping to tap into your knowledge.  Also hoping I'm posting in the right place.  Please excuse me if not.
      I live in NE Minnesota, and am looking for a WH tractor for mowing and snowblowing.
      I have a couple of questions I'd like your opinion/knowledge on, mostly about snow blowers and steering:
      Did all 520H/C models after 1991 have gear reduction steering?  How do I know if a machine has gear reduction or not?
      Do the newer xi series have gear reduction?  I think the 520/2/3xi offered power steering as an option, but do non-power steering models incorporate gear reduction?
      I'm leaning toward 2 stage blower, just because it seems heavier duty, and it snows a ton in NE MN.  Are the 2 stage units worthwhile?
       I was lucky enough to work for Toro for a few years, and really want to find a red machine.  Lots of green around here, but hoping to stay RED.  Thanks for your help.
      Greg
    • Berco
      By Berco
      I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
    • katanski
      By katanski
      Can someone tell me how long is the drive belt from the engine to the mower deck is? 522xi with a 52" side discharge mower deck.
