Similar Content
By MachXXII
Does anyone know what battery a 1988 252-H needs. I looked around and couldn’t really find an answer. Thanks
By mryanpilarski
Is there anybody who would be able to draw out on these photos which way the stator wire runs? i have it coming out at the 4:00 position right now, then all the way around behind the stator counter-clockwise to where the voltage rectifier would be on the left hand side (8:00)
I put the wire holder bracket on the bolt where the breather tube is, these photos are before that.
The way i have it now, the wire comes awfully close to the flywheel and I just don't want it to rub on there and I am out a stator
Thanks!
By Chuck14025
1994 520 H. Starter just clicks.
1. Battery 12.6V, load test OK., New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically.
2. Not able to find article on this problem when searching. There must be dozens. How do I find them?
3. Can I test the starter without taking it out?
4. Is there a 'kill' relay?
thank you...
By indywheelhorsenut
Started fine 2 weeks ago. I left key in ignition and fear grandson may have turned it slightly to right a week ago.. not enough to engage starter but perhaps enough to drain battery.
Went to start it yesterday and no charge at all. Started charging it and battery began to take charge. However starter turned over but didnt turn engine over.
Question is do I just need more of a charge (more amps) or do I have another problem?
Lol, have 5 inches of snow headed here starting tonight so I need to get ahead of this today.
By tntatro
The stator and flywheel on this engine are different than others I have worked on so far. The stator is smaller in diameter and has a wire that runs out to a part that looks like an ignition coil but has no plug wire. I am wondering what it is and how do I wire it?
I'm not 100% positive that I put it back in the same spot it came but I think I did. I gapped it at .020" from the bump that sticks out on the flywheel, it is magnetized.
