mikeeyre74
Which holes for attaching decks?
mikeeyre74
 I have had several different tractors from the late 70s to the lead… Every time I try to move one of the mower decks to another tractor, it seems to be variable and mysterious which hole in the lift arm down below (that the deck attaches to the lift rod), and which hole on on the handle that you  pull on that you're supposed to use. For instance, do I use the forward most hole or the rear most hole to attach the chain/J hook trunnion ?  And on the lift handle itself, there are three holes that I can use… Do I use the one closest to the handle or farthest away or the one in the middle?   I Can't find anything in any of the user manuals or deck manuals in regards to this.
stevasaurus
See if this helps...  :)
  • Like 3
mikeeyre74
Genius!
