Dball
Info on wheels
Dball
Do any of you guys know what wheels are interchangeable with a 1991 520 I was looking at a set that was off a jhon deer.i need to get new rear rims and would like to know what I can use with out doing any mods  thank you all for any help
roadapples
Most  GT wheels will bolt up, (5-4 1/2 bolt pattern) .Wheel horse has 1 1/4" backspacing, most others have more. You may need spacers depending on how much room you have...
RandyLittrell
John Deeres usually have deep backspacing, I use them on pullers to get the tire and wheel closer to the frame.
I think most cub cadets have the same backspacing as WH's, I could measure on tomorrow.
Randy
Edited by RandyLittrell
Dball
If u could do that randy that would be grate thanks u .I am currently looking at a set of jd rims but not sure of the spacing ect an would like to be able to find rims with same spacing as my horse
Dball
I've been looking on ebay and d can't find much what I do find I am unable sure as to if the back spacing is correct ect .is their any after market rims i can get it have a wanted ad up in the wanted section just really need 23x10.5x12 rims the ones on my tractor are rusted out won't hold air ect
gwest_ca
If your rims have rusted beads and that is why they leak why not add tubes to the tires. I have done that to all of mine.
Garry
