TIMOTHY McCLELLAN
LX 425 TORO 44"DECK
TIMOTHY McCLELLAN
I have a Toro LX 425 W/ 44" DECK .I NEED TO KNOW WHAT THE CROSS SECTION AND LENGHT OF THE DECK BELT IS ?
gwest_ca
Toro lists 6 different 2007 models and they all show a 42" mower deck with 2 blades.
The mower drive belt is Toro 112-5800
Gates make a replacement belt # 6663BR  which shows as 1/2" x 109-3/8". Napa uses the same Gates part number.
Garry
TIMOTHY McCLELLAN
THANK YOU FOR THE INFO YOUR GREAT !
  • Similar Content
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • Xearl
      By Xearl
      I am trying to find out what the belt length is on a 48 inch deck for a 523DXI  part no. 95-3878 . Dealer wants over $70.  I want to find it at a reasonable price.
    • DANIEL/ALEASHA
      By DANIEL/ALEASHA
      I have a 1968 Raider 10 I need the belt size if anyone knows it
    • Yankee64
      By Yankee64
      Hello,
      I have a C-160 with 16HP Kohler that had a 42" deck on it. That deck needs some work so I switched it to my 5-0721 36" deck that I put a new deck belt and new blades on, but can't get it hooked up. I can't find the transfer belt size for this combo, I think that's what it's called, the belt to the PTO.
      I don't know what I hit, but new kids across the ally have been throwing rocks in my yard at a ground hog (all over, they have rock pile from the garden) and whatever it was, it jammed on the spindle of the 42" deck and ripped the deck where the spindle mounts. I'm going to fix it up nice while it's not in use.  Wouldn't you know, I started in the back yard and the front is starting to look bad. I've been fiddling for a few days and bought a couple of  belts but haven't gotten it right. If anyone knows the belt size for a C-160 with a 5-0721 36" deck, I'd sure appreciate your assistance.
    • Road-Track
      By Road-Track
      I blew a drive belt on my 1983 C-145 hydro and the belt measured 82". I looked up the correct belt and have seen many different sizes called out.
      Is 5/8" x 81" correct?
      Is 5/8" x 81.5" correct?
      or
      Is 5/8" x 82" correct?
      I also saw 98" using the same wheelhorse number????
      Any help would be appreciated,
      Thanks!
