oldredone
414-8 Brake Drum Bolt
oldredone
So I was crusing down the lawn yesterday when I saw this shiny piece of metal in the grass.. Coming up on it i could see it looked like a small metal wheel. i went to put my foot on the brake to stop and check it out and :(petal to the floor!
thankfully I got the tractor stopped but quickly found out this was my brake drum which had snuck out sometime earlier in the cut.  It's from a 1986 414-8.  Does anyone know the size / type of bolt and washer that hold this thing into the tranny?
thanks all!!!
Edited by oldredone
pics
daveoman1966
Your brake DRUM looks like the DD hol;e is really wallowed out....  item # 1 in this schematic.  it is part # 106719 and I have a good one.
The bolt that holds it on is item 2 in the schematic and is part # 110234... I ahve that too.
my direct email is:
daveoman@windstream,.net
Edited by daveoman1966
KC9KAS
857 horse
Last time i lost a small wheel off my tractor it had a tire on it,,,,,:text-lol:
Welcome to RED SQUARE$ !!!!!!!!!!!
  • Like 4
Pullstart
I'm thinking this would be a 3/8-16 bolt, not sure of length but probably 1.5 - 2"
gwest_ca
Have the 110234 replacing 513356
3/8"-16x3/4" Nylok
Garry
oldredone
Update!
Thanks to all for their help. Dave, I took a close look and attached some pics, the drum, when dry fitted, sizes up tight to threaded "axle" so to speak.  No play whatsoever when the wheel is held tight. My local toro dealer got me hooked up with an appropriate washer and I found a bolt that worked. Pullstart, right on, 3/8" 16.  Now I just have to snug it up when I get home and dial in the brake.
Thanks again everyone!
daveoman1966
good news.... glad for you it was a simple fix.
